Converting homebridge-broadlink-rm IR codes to broadlink integration codes
Hi there, I would like to use the codes I’ve already captured from homebridge-broadlink-rm to control my air conditioner (since I’ve lost the remote to my air conditioner). However, I’m unsure how to go about converting the codes. I’ve attempted decoding the hex string and re-encoding it with base64 (same format as the ones in the broadlink integration) but to no avail. Does anyone have any experience with this?
Hi, in this page you can convert the HEX string of the IR/RF commands you captured on homebridge-broadlink-rm, and generate the Base64 message to use in Home Assistant. Good luck!
https://base64.guru/converter/encode/hex
Does that work?
EDIT: no, appears not
