Calculating the COP for a heat pump is easy; output power divided by the input power. But over which period do you calculate the COP? Over a day, week, month? All give a COP and all are different depending on outside temperatures etc.
While tuning the heat pump configuration I wanted to understand the impact on the COP between two runs, so below is the automation I use to calculate the COP per run.
How to install
- Create in \esphome\packages the file cop_per_run.yaml and copy this code into that yaml
- Ensure that in the configuration.yaml you have the following lines of code
- Restart home assistant
homeassistant:
packages: !include_dir_named packages
Pre-requisites
- EMS-ESP gateway to read values from the heat pump, see LINK
- Device to measure the power consumption from the heat pump. I use LINK
Sensors being used
sensor.boiler_compressor_activity (or sensor.boiler_hpactivity)
This EMS-ESP gateway sensor gives the state of the compressor. Values are none, heating, hot water and defrost -
sensor.boiler_compressor_power_output
This EMS-ESP gateway sensor gives the current power output of the compressor. -
sensor.kwh_meter_3_phase_nnnn_total_power_import
This kWh device sensor give the measured power consumption of the compressor.
How it works
- um_heatpump_compressor_power_output
The sensor.total_compressor_power_output is calculated by integrating the sensor.boiler_compressor_power_output. This sensor.total_compressor_power_output is then used in utility meter um_heatpump_compressor_power_output which gets reset to 0 each time the sensor.boiler_compressor_activity is changing state.
So at the end the um_heatpump_compressor_power_output contains the power output per compressor state; heating, hot water…
- um_heatpump_power_input
The um_heatpump_power_input is using the sensor.kwh_meter_3_phase_nnnn_total_power_import which gets reset to 0 each time the sensor.boiler_compressor_activity is changing state.
So at the end the um_heatpump_power_input contains the power input per compressor state; heating, hot water…
- sensor.cop_run_heating, _hot_water and _defrost
The COP is calculated by dividing the um_heatpump_compressor_power_output by the um_heatpump_power_input. The value is put to zero depending on the compressor activity
# Calculate the COP per run on a NEFIT / BOSCH heatpump
# Calculating the COP for a heat pump is easy; output power divided by the input power. But over which period
# do you calculate the COP? Over a day, week, month? All give a COP and all are different depending on outside
# temperatures etc. While tuning the heat pump configuration I wanted to understand the impact on the COP between
# two runs, so below is the automation I use to calculate the COP per run.
# How to install
# 1. Create in \esphome\packages the file cop_per_run.yaml and copy this code into that yaml
# 2. Ensure that in the configuration.yaml you have the following lines of code
# 3. Restart home assistant
# homeassistant:
# packages: !include_dir_named packages
# Pre-requisites
# 1. EMS-ESP gateway to read values from the heat pump, see [LINK](https://github.com/emsesp)
# 2. Device to measure the power consumption from the heat pump. I use [LINK](https://www.homewizard.com/nl/shop/wi-fi-kwh-meter-3-fase/)
# Sensors being used
# * sensor.boiler_compressor_activity (or sensor.boiler_hpactivity)
# This EMS-ESP gateway sensor gives the state of the compressor. Values are none, heating, hot water and defrost
# * sensor.boiler_compressor_power_output
# This EMS-ESP gateway sensor gives the current power output of the compressor.
# * sensor.kwh_meter_3_phase_nnnn_total_power_import
#. This kWh device sensor give the measured power consumption of the compressor.
# How it works
# * um_heatpump_compressor_power_output
# The sensor.total_compressor_power_output is calculated by integrating the sensor.boiler_compressor_power_output.
# This sensor.total_compressor_power_output is then used in utility meter um_heatpump_compressor_power_output,
# which gets reset to 0 each time the sensor.boiler_compressor_activity is changing state.
# So at the end the um_heatpump_compressor_power_output contains the power output per compressor state; heating, hot water.
# * um_heatpump_power_input
# The um_heatpump_power_input is using the sensor.kwh_meter_3_phase_nnnn_total_power_import which gets reset to 0
# each time the sensor.boiler_compressor_activity is changing state.
# So at the end the um_heatpump_power_input contains the power input per compressor state; heating, hot water...
# * sensor.cop_run_heating, _hot_water and _defrost
# The COP is calculated by dividing the um_heatpump_compressor_power_output by the um_heatpump_power_input.
# The value is put to zero depending on the compressor activity
template:
- sensor:
- name: "COP run heating"
unique_id: sensor.cop_run_heating
unit_of_measurement: ""
state: >
{% set power_output = states('sensor.um_heatpump_compressor_power_output') | float %}
{% set power_input = states('sensor.um_heatpump_power_input') | float %}
{% if is_state('sensor.boiler_compressor_activity', 'heating') %}
{{ (power_output / power_input) | round(2, default=0) }}
{% else %}
0
{% endif %}
availability: "{{ states('sensor.um_heatpump_compressor_power_output')|is_number and states('sensor.um_heatpump_power_input')|is_number }}"
- name: "COP run hot water"
unique_id: sensor.cop_run_hot_water
state: >
{% if is_state('sensor.boiler_compressor_activity', 'hot water') %}
{% else %}
0
{% endif %}
- name: "COP run defrost"
unique_id: sensor.cop_run_defrost
state: >
{% if is_state('sensor.boiler_compressor_activity', 'defrost') %}
{% else %}
0
{% endif %}
- platform: integration
method: left
source: sensor.boiler_compressor_power_output
name: "Total compressor power output"
unit_time: h
max_sub_interval:
seconds: 10
utility_meter:
um_heatpump_power_input:
source: sensor.kwh_meter_3_phase_3c39e72c1bb8_total_power_import # change this to your sensor name
cycle: yearly
um_heatpump_compressor_power_output:
source: sensor.total_compressor_power_output
cycle: yearly
automation:
- alias: Reset um_heatpump on changing state
description: 'Reset the um_heatpump_power_input and um_heatpump_compressor_power_output on changing compressor activity'
triggers:
- platform: state
entity_id:
- sensor.boiler_compressor_activity
conditions: []
- service: utility_meter.calibrate
value: '0'
entity_id:
- sensor.um_heatpump_power_input
- sensor.um_heatpump_compressor_power_output
mode: single
