I am using a from HA unsupported tuya device to measure the water level. Within tuya I therefore change the brightness of a lamp depending on the water level, i.e. 90% water level = 90% brightness.
The lamp can be seen and worked with in HA. Now, I would like to copy this brightness value in a template sensor variable, which I later can display i.e. as a gauge. I only worked with sensors as a source in templates.
This isn’t working, but you might get an idea what I am looking for:
- name: "MeterL Water Prozent"
device_class: power
unit_of_measurement: "%"
state: "{{ ( states('light.l_f_jnb_watertank_level.brightness') | float | round(0)) }}"
