Logger: homeassistant.components.hassio
Quelle: components/hassio/websocket_api.py:135
Integration: Home Assistant Supervisor (Dokumentation, Probleme)
Erstmals aufgetreten: 26. Mai 2024 um 19:39:30 (5 Vorkommnisse)
Zuletzt protokolliert: 21:00:07
Failed to to call /addons/7d06b5a0_argon_one_temp_linear/stats - Container addon_7d06b5a0_argon_one_temp_linear is not running
Failed to to call /addons/7d06b5a0_argon_one_v3_temp_linear/stats - Can't read stats from addon_7d06b5a0_argon_one_v3_temp_linear: Expecting value: line 1 column 1 (char 0)
Core 2024.5.5
Supervisor 2024.05.1
Operating System 12.3
Frontend 20240501.1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ArgonOne Active Linear Cooling
Actively keeping your Argon One cool.
Add-on version: 30a
You are running the latest version of this add-on.
System: Home Assistant OS 12.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.5.5
Home Assistant Supervisor: 2024.05.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
checking i2c port 0 at /dev/i2c-0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
not found on /dev/i2c-0
checking i2c port 1 at /dev/i2c-1
not found on /dev/i2c-1
checking i2c port 10 at /dev/i2c-10
not found on /dev/i2c-10
checking i2c port 22 at /dev/i2c-22
/run.sh: line 117: thePort: unbound variable
not found on /dev/i2c-22
[cmd] /run.sh exited 1
can any help!
