Core 2025-01 qemu-guest-agent does not work
I have been running my HA on a synology NAS for years. The backups run on the nas without any problems on their own by scheduling.
I have never had any problems so far. Since I have installed core version 2025-01 it is as if qemu-guest-agent does not work.
My backups say “consistent with failures” whereas before they said “file system consistent”.
Since core 2025-01 when I make a backup with the machine off it says “file system consistent” but if I make a backup with the machine on it says “consistent with failures” before it was always fine with the machine off as well as on.
Does anyone have the same problem?
as indicated from synology (¿Cómo instalo Synology Guest Tool en máquinas virtuales? - Synology Centro de conocimientos) to solve this situation you must install qemu-guest-agent but HA is supposed to bring it as standard, right?
