Correct automation?
Hello friends. This automation is correct. I need it to send a message when it exceeds a temperature or when it falls below a certain value.
greater than 29.5
less than of 27.5
If I run the automation it sends the message. But if I let the automation run it doesn’t send it.
Thanks a lot
alias: Alarma error sensor
description: Envía una notificación cuando el sensor de temperatura falla
  - platform: numeric_state
    entity_id: sensor.temperatura_plantado
    above: '29.5'
    attribute: temperature
    below: '27.5'
condition: []
  - device_id: 7e994f7aexxxxxxx
    domain: mobile_app
    type: notify
    message: El sensor de temperatura parece estar fallando
    title: Alerta
mode: single
It does look correct for what I can see.
1 - is the automation enabled
2 - verify the entity_id is correct in developer tools
You could try outputting the value of sensor.temperatura_plantado in your notification.
message: >-
  {{states['sensor.temperatura_plantado']}}
also
  1. just a good habit
when dealing with numeric_state
dont use the quotes around the numbers
    above: 29.5
https://www.home-assistant.io/docs/automation/trigger/ 1/2 way down
The use of the quotation marks was automatic. I removed the quotes and it worked.
Now what I noticed is that execution is not instantaneous. It takes a few minutes. Can be?
Can be what?
You do realise the temperature needs to cross the boundary of the state condition?
Sorry. Is the translation.
The question is how many minutes do you run the automations?
