Correct way to use cloudflared in docker compose
I use docker, so I cannot install the cloudflared plugin. AI suggested me to do this:
version: '3.8'
services:
  homeassistant:
    # ... your existing home assistant config ...
  cloudflared:
    image: cloudflare/cloudflared:latest
    container_name: cloudflared
    restart: unless-stopped
    command: tunnel run
    environment:
      - TUNNEL_TOKEN=YOUR_TOKEN_HERE # Paste the token from Step 1
I would like to know how safe this is. If I understand, it will expose localhost:8123 to anyone that knows my subdomain, which is public. I think I can add a /path to cloudflare, with some hidden token that only I know. It will then show homeassistant as HTTP or HTTPs? If https, will it be signed by cloudflare?
Then I need to allow reverse proxies:
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.16.0.0/12      # Allows default Docker networks
    - 192.168.1.0/24     #  ??? is this needed?
Is there something more I need to do?
