Hi.
I have an Aqara sensor as in the picture. I need to correct the measurement because it cheats me a bit.
How can I do this?
Hi.
How can I do this?
Create a template sensor and correct the value this way:
{%- set x = states('sensor.my_annoying_aqara') |float(0) %}
{{ x - 0.1 }} ## or whatever value
If you use zigbee2mqtt, just enter correction in field temperature_calibration.
I don’t know is this supported by ZHA.
I made this entry:
{%- set x = states('sensor.salon') |float(0) %} {{ x - 0.8 }} ## or whatever value
I get an error response. What am I doing wrong:
missed comma between flow collection entries (2:2)
1 | entity: sensor.salon
2 | {%- set x = states('sensor.salon' ...
Is this a piece of your template sensor? Please post the whole code.
I’m posting screenshots because I’m typing from a smartphone. Configuration doesn’t seem to work. For example, I also wanted to change the unit.
Don’t use comma, use point:
Unfortunately, neither dot nor comma work. Nothing changes for me.
Post a screenshot of state + attributes of that sensor (—> Developer Tools —> States).
I do it slightly different, but you’ll get the same result and probably the same error. …but give it a try:
template:
- name: "Balkon"
unique_id: balkon_temp
device_class: temperature
unit_of_measurement: °C # I guess K for you?
state: "{{ ( states('sensor.salon') | float(0) +1.2 ) }}" #1.2 is the offset here
Can you show sensor.balkon
I am asking you for help. Give me what I should enter in configuration.yaml for this correction to work. I’m doing it for the first time, so I’ll know.
If I didn’t type it in and didn’t modify it, unfortunately it doesn’t work.
The configuration is correct without errors but it doesn’t work.
Or maybe I need to install some add-on to the system??
Seems to be a quite normal temperature sensor.
What in detail doesn’t work?
Hello. Can you send me the finished full code for temp correction? This thing doesn’t work for me. I must be doing something wrong. When I enter this code in the developer’s tools in the templates, it works, and when I enter this code in configuration.yaml, it no longer works. Maybe I’m missing some add-on?
template:
- sensor:
- name: Test Temp Correction
unique_id: test_202211290712
state: |-
{{ x - 1.5 }}
attributes:
real: |-
{{ x }}
