Could not load HACS!
Hi guys,
I have this issue
[GitHub returned 401 for https://api.github.com/repos/hacs/integration] - Could not load HACS!
and as result HACS doesn’t load.
Didn’t change anything in my config which could lead to this, I think.
can anyone help or is experiencing the same issue?
I had the same.
I did need to make a new accestoken: https://hacs.xyz/docs/configuration/pat
so did you remove HACS integration, create a new token, and re-add it?
I am not sure where I have to input the token!
Edit: removed integration, re-added with a new token! Thanks!
Yes
Thats what I did
When installing integration it wil ask for the Token
