Could not update to 0.79.x
I have hassio running HA 0.78.3. But I could not upgrade to 0.79.x
I don’t get an update button in the the GUI and the terminal command hassio ha update does not work.
Any idea what I could do?
Jan
core-ssh:~# hassio ha info
"result": "ok",
"data": {
    "version": "0.78.3",
    "last_version": "0.78.3",
    "machine": "raspberrypi3",
    "image": "homeassistant/raspberrypi3-homeassistant",
    "custom": false,
    "boot": true,
    "port": 8123,
    "ssl": false,
    "watchdog": true,
    "wait_boot": 600
core-ssh:~# hassio su info
    "result": "ok",
    "data": {
        "version": "131",
        "last_version": "131",
        "channel": "stable",
        "arch": "armhf",
        "wait_boot": 5,
        "timezone": "UTC",
        "addons": [
                "name": "Git pull",
                "slug": "core_git_pull",
                "description": "Simple git pull to update the local configuration",
                "state": "stopped",
                "version": "5",
                "installed": "5",
                "repository": "core",
                "icon": false,
                "logo": true
                "name": "Pi-hole",
                "slug": "a0d7b954_pi-hole",
                "description": "Network-wide ad blocking using your Hass.io instance",
                "state": "started",
                "version": "2.0.4",
                "installed": "2.0.4",
                "repository": "a0d7b954",
                "icon": true,
                "logo": true
                "name": "Node-RED",
                "slug": "a0d7b954_nodered",
                "description": "Flow-based programming for the Internet of Things",
                "state": "stopped",
                "version": "0.7.0",
                "installed": "0.7.0",
                "icon": true,
                "logo": true
                "name": "Check Home Assistant configuration",
                "slug": "core_check_config",
                "description": "Check current Home Assistant configuration against a new version",
                "state": "stopped",
                "version": "0.9",
                "installed": "0.9",
                "icon": false,
                "logo": true
                "name": "SSH server",
                "slug": "core_ssh",
                "description": "Allows connections over SSH",
                "state": "started",
                "version": "4",
                "installed": "4",
                "icon": false,
                "logo": true
                "name": "UniFi Controller",
                "slug": "a0d7b954_unifi",
                "description": "Manage your UniFi network using a web browser",
                "state": "stopped",
                "version": "0.3.0",
                "installed": "0.3.0",
                "icon": true,
                "logo": true
                "name": "Samba share",
                "slug": "core_samba",
                "description": "Expose Hass.io folders with SMB/CIFS",
                "state": "started",
                "version": "5",
                "installed": "5",
                "icon": false,
                "logo": true
        "addons_repositories": [
            "https://github.com/hassio-addons/repository"
Log from GUI
18-10-05 14:47:42 WARNING (MainThread) [hassio.homeassistant] Version 0.78.3 is already installed
Not sure why you don’t get the update option.
The following works for me to update
