Count down Timer function?
Hi - is there a simple way to create a count down timer in Home Assistant?
I want to start my pool water feature and then let it stop in 3 hours etc. I dont want to use a permanent schedule - just want to use it when we are outside.
I have installed simple scheduler that works great for devices i want to switch on or off during the same time each day - but I would also like to use a timer.
If you have the pool water feature controllable in Home Assistant, you could just have an automation that is triggered when you turn the switch on, then the action could be:-
  - delay: 03:00:00
  - data: {}
    entity_id: switch.your_switch
    service: switch.turn_off
Thanks - but that means it will always switch off in 3 hours - I want to be able to set a custom time period each time I switch it on in HA app.
You could link the delay to an input_number slider, or something similar and then just pop the related entities on to a card in lovelace.
     - delay: '00:{{ states('input_number.minutes') | int }}:{{ states('input_number.seconds') | int }}'
     - service: switch.turn_off
       entity_id: switch.something
You can set an input_number to configure the minutes : -
    - service: switch.turn_on
      entity_id: switch.my_switch
    - delay: '00:{{ states('input_number.pump_on_minutes') }}:00'
Edit: Adam beat me to it !
There is a Timer that might be useful. I haven’t looked in to the details.
Hi, this my example of how i use a timer to controll a fan. This way you can change the duration of the timmer from the front end, if you wish.
1) create a inmput number example:
  ha_fan_timmer_min:
    initial: 10
    min: 0
    max: 55
    step: 1
    icon: mdi:timer
  ha_fan_timmer_sec:
    initial: 30
    min: 0
    max: 60
    step: 1
    icon: mdi:timer
2) Automation example:
  - alias: 'HA temperature fan'
      platform: numeric_state
      entity_id: sensor.ha_temperature
      above: 28
      for:
        minutes: "{{ states('input_number.ha_fan_timmer_min')|int }}"
        seconds: "{{ states('input_number.ha_fan_timmer_sec')|int }}"
    condition:
      - condition: state
        entity_id: 'binary_sensor.pfsense_status'
        state: 'on'
        entity_id: switch.ha_fan
  - alias: 'HA temperature fan off'
      below: 26
      for:
        entity_id:
          - switch.ha_fan
