Counter increments every 24 hours since toothbrush entity is off
I’m trying to do an automation that send me a telegram notify every 24 hours after the toothbrush enter the ‘off’ state after a usage.
This is what I have done:
- id: '1700661861451'
  alias: Toothbrush Alert on Inactivity
  description: 'If no change in toothbrush status is detected for 24 hours, an alert is sent'
    platform: state
    entity_id: binary_sensor.toothbrush
    to: 'off'
    for:
      hours: 24
    - service: counter.increment
      entity_id: counter.toothbrush_timer
    - service: telegram_bot.send_message
        title: 'Casa nonna'
        message: 'Toothbrush: no data for {{ states.counter.toothbrush_timer.state | int * 24 | string }} hours'
- id: 'reset_toothbrush_timer'
  alias: Reset Toothbrush Timer on State Change
    platform: state
    - condition: state
      state: 'on'
    - service: counter.reset
The problem is that the counter increments only after the first 24 hours with toothbrush in ‘off’ state, so if the toothbrush isn’t used for 48 hours I didn’t receive any notification.
I am doing this to monitor the health of my grandmother who has alzheimer; I brush my teeth regularly and I don’t need a reminder :sweat_smile:
Do you mean you receive a notification only once, after 24h, and not a second time after 48h? Yes, that’s what that automation does; the “for” will “wait” 24h before triggering once.
If you want a notification every 24h, you’ll probably have to use a timer pattern trigger.
Yes I want a notification every 24h.
Can you help me to use a timer pattern trigger?
I’d do this by adding a trigger for 24h since the automation triggered, plus a condition that the toothbrush change to off is still more than 24h ago. Then you don’t need the timer.
state_attr('automation.ENTITY_ID', 'last_triggered) shows the last time that the action: was run, not just when the trigger: section fired.
    - platform: state
      to: 'off'
      for:
        hours: 24
    - platform: state
      entity_id: automation.toothbrush_alert_on_inactivity
      attribute: last_triggered
      for:
        hours: 24
    - platform: event
      event_type: automation_reloaded
    - platform: homeassistant
      event: start
  condition:
    - condition: state
      state: 'off'
      for:
        hours: 24
        title: 'Casa nonna'
        message: >
          {{ ((now() - states['binary_sensor.toothbrush']['last_changed']).total_seconds() / 3600)|int(0) }} hours
I tried this by changing the 24 hours in 1 minute and the message arrive only once after the first minute
Ah yes, needs a “restart” trigger to get it going. With the two triggers I’ve just added, it works for me — although this means you’ll get a notification whenever you restart or reload automations if the toothbrush is over 24h without use.
Am I missing something??
    - platform: state
      to: 'off'
      for:
        minutes: 1
    - platform: state
      for:
        minutes: 1
    - platform: event
      event: start
  condition:
    - condition: state
      state: 'off'
      for:
        minutes: 1
        title: 'Casa nonna'
        message: >
          {{ ((now() - states['binary_sensor.toothbrush']['last_changed']).total_seconds() )|int(0) }} seconds
It doesn’t work, it still sends only the first notification
Look at the automation traces: is it triggering but not completing? Is there a throttle on telegram messages?
Make sure the automation entity ID is correct in the trigger: it’s possible to rename it elsewhere in the system.
Yes you are right, that was my mistake. Thank you very much
