This is a blueprint to support multi-clicks with the Philips Hue Dimmer again, after zigbee2mqtt update this is not support anymore (at least without legacy options)
It subscribes to the 4 different release events and starts a debouncing counter. If another event is fired within the defined threshold the automation restarts and increments a counter. Once the timer expires, another event is fired with payload of the button name and the counter.
The output looks like:
event_type: hue_dimmer_debounced
count: 1
trigger: off_press_release
So you can create any type of automation with that event as a trigger.
You just need to specify the dimmer device and your preffered debounce threshold.
I could not find a way to do it without a helper entity, so you need to create/specify a counter as helper.
Maybe you can suggest how to update to get rid of the helper.
blueprint:
name: Hue Dimmer Counter
description: Debounces the Hue Dimmer events to enable click counters and fires an event with that counter as payload once the timeout is reached
domain: automation
input:
hue_dimmer_device_id:
description: This is the Hue Dimmer device
selector:
device:
filter:
manufacturer: Philips
model: Hue dimmer switch
debounce_time:
description: Maximum time between two triggers before final event is fired
default: 500
selector:
number:
min: 0
max: 10000
unit_of_measurement: "ms"
helper_counter:
name: "[Helper] Internal click counter"
description: used in the automation to count clicks between the triggers
selector:
entity:
filter:
domain: counter
triggers:
- domain: mqtt
device_id: !input hue_dimmer_device_id
type: action
subtype: on_press_release
trigger: device
enabled: true
- domain: mqtt
type: action
subtype: up_press_release
trigger: device
- domain: mqtt
type: action
subtype: down_press_release
trigger: device
- domain: mqtt
type: action
subtype: off_press_release
trigger: device
- trigger: event
event_type: hue_dimmer_counter_event_internal
event_data: {}
conditions: []
actions:
- choose:
- conditions:
- condition: not
conditions:
- condition: trigger
id:
- event
sequence:
- action: counter.increment
metadata: {}
data: {}
entity_id: counter.huedimmerclickcounter
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: !input debounce_time
- event: hue_dimmer_counter_event_internal
event_data:
payload: "{{trigger.payload}}"
- conditions:
id:
- event
sequence:
- data:
message: Test {{ trigger.event.data.payload }}
action: notify.mobile_app_a063
enabled: false
- event: hue_dimmer_debounced
event_data:
count: "{{ states('counter.huedimmerclickcounter') | int }}"
trigger: "{{ trigger.event.data.payload }}"
- action: counter.reset
metadata: {}
data: {}
mode: restart
