Cover automation based on temperature - problems
Hey there, I tried to make an automation for my windows.
Closing works but opening does not work.
alias: Outdoor to 🥵
description: ""
triggers:
  - trigger: numeric_state
    entity_id:
      - sensor.balkon_temperature
    above: sensor.temp_hum_co2_temperature
    for:
      hours: 0
      minutes: 2
      seconds: 0
conditions: []
actions:
  - action: cover.close_cover
    metadata: {}
    data: {}
      entity_id:
        - cover.alle_fenster
        - cover.alle_markisen
mode: single
I have tried it with above: "{{states('sensor.balkon_temperature')|float0}}" as well but get an error “Message malformed: expected float for dictionary value @ data[‘above’]”
alias: Indoor to 🥵
description: ""
triggers:
    entity_id:
      - sensor.temp_hum_co2_temperature
    above: sensor.balkon_temperature
conditions: []
actions:
  - action: cover.open_cover
    metadata: {}
    data: {}
      entity_id: cover.alle_fenster
mode: single
anyone some ideas?
Thx
If you want to compare two entities, you must use template.
Example:
Outdoor to
    value_template: >
      {{ states('sensor.balkon_temperature')|float(0) > states('sensor.temp_hum_co2_temperature')|float(0) }}
    for:
      minutes: 2
Indoor to
    value_template: >
      {{ states('sensor.temp_hum_co2_temperature')|float(0) > states('sensor.balkon_temperature')|float(0) }}
Thanks mate, that did it.
Just to clarify, what you had originally does work. However, that construction is better suited for uses where the entity used in “above” has a relatively static value. This is because it will only be triggered by when the state of sensor.balkon_temperature changes from below the state of sensor.temp_hum_co2_temperature to above it…
The value has to cross the threshold and it has to be sensor.temp_hum_co2_temperature that changes.
Using a Template trigger as @krskrab suggested is the more compact option, but another method would be to use 2 Numeric state triggers as follows:
alias: Indoor to 🥵
description: ""
triggers:
    entity_id: sensor.temp_hum_co2_temperature
    for: "00:01:00"
    entity_id: sensor.balkon_temperature
    below: sensor.temp_hum_co2_temperature
    for: "00:01:00"
actions:
    metadata: {}
    data: {}
mode: single
