graLf
(GraLf)
July 6, 2025, 9:53pm
1
Hi there, I just installed some window open/close sensors, so now i want to change the default action when you want to close the cover to use a script wich will check that point.
I tried editing in yaml mode the button, but then all th icons disspaeared.
I’d suggest using a cover template to call your script
# Example state-based configuration.yaml entry
template:
- cover:
- name: Garage Door
state: "{{ states('sensor.garage_door')|float > 0 }}"
device_class: garage
open_cover:
action: script.open_garage_door
close_cover:
action: script.close_garage_door
stop_cover:
action: script.stop_garage_door
# Example trigger-based configuration.yaml entry
template:
- triggers:
- trigger: state
entity_id: sensor.garage_door
cover:
- name: Garage Door
state: "{{ trigger.to_state.state|float(0) > 0 }}"
open_cover:
close_cover:
stop_cover:
graLf
(GraLf)
July 14, 2025, 11:01am
3
thank you very much. Nice to know.
anyone who woould explain the two examples codes for me, please?
in the first example, what does this do?
and in the second one, what about this piece ?
- triggers:
- trigger: state
cover:
- name: Garage Door
thanks in advance
graLf
(GraLf)
July 18, 2025, 6:25am
4
I´ve tryed this
template:
- cover:
- name: Persiana - 2
device_class: cover
open_cover:
action: script.open_persiana_2
close_cover:
action: script.close_persiana_2
stop_cover:
action: script.stop_persiana_2
but I can´t find a espected Persiana - 2 cover anywhere
graLf:
Does it appear if you remove the - 2 from the name?
graLf
(GraLf)
July 23, 2025, 4:56pm
6
hi there, just fixed it. with this code
cover:
covers:
persiana_segura_2:
friendly_name: "Persiana Segura 2"
open_cover:
service: cover.open_cover
entity_id: cover.2
close_cover:
service: script.cerrar_persiana_2
stop_cover:
service: cover.stop_cover
entity_id: cover.2
position_template: "{{ state_attr('cover.2', 'current_position') }}"
set_cover_position:
service: cover.set_cover_position
entity_id: cover.2
position: "{{ position }}"
icon_template: >
{% if is_state('cover.2', 'open') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
You realize the Cover template info provided earlier in this thread was the ACTUAL solution. Your posted resolution is specific to YOUR needs.
I felt the need to mention this after seeing your other post
Glad you figured it out…
graLf
(GraLf)
July 24, 2025, 6:47am
8
Sorry I don’t get what you mean.
