Cover current_operation is not returning correctly
I am using one button to both start and stop a motor. If pressed when the motor is stopped, then I need it to start. But if pressed when the motor is started, then I need it to stop.
This motor controls a cover, so I’m using the Template Cover component as well.
To figure out if the motor is stopped or not, I’m using this lambda in an if statement in a binary_sensor:
lambda: 'return (id(ropener_cover).current_operation != COVER_OPERATION_IDLE);'
This should allow me to know if the motor is not idle. And if not idle, then stop. However, it does not work, it never evaluates to true and skips this step and I have no idea what I’m doing wrong. The reference I"m going off of for this is here and here.
The full YAML is below. The line above is in the binary_sensor section, about half way down. Thank you!!!
external_components:
  - source: github://slimcdk/esphome-custom-components
    components: [tmc2209_hub, tmc2209, stepper]
substitutions:
  steps_per_revolution: "1600"
  max_distance_revs: "float(231.9207)"
  max_distance_steps: "${max_distance_revs}*${steps_per_revolution}"
api:
ota:
  - platform: esphome
logger:
  level: VERBOSE
esp32:
  board: esp32-c6-devkitc-1
  framework:
    type: esp-idf
wifi:
  ssid: !secret wifi_ssid
esphome:
  on_boot:
    then:
    - tmc2209.configure:
        direction: cw
        microsteps: 8
        interpolation: true
    - tmc2209.stallguard:
        threshold: 50
    - tmc2209.currents:
        standstill_mode: freewheeling
        irun: 26
        ihold: 0
        tpowerdown: 0
        iholddelay: 0
    - if:
        condition:
          binary_sensor.is_off: limit_switch_1  # Check if switch is pressed
        then:
          - stepper.report_position:
              position: !lambda return ${max_distance_steps};
    - if:
        condition:
          binary_sensor.is_off: limit_switch_2  # Check if switch is pressed
        then:
              position: 0
uart:
  tx_pin: 1
  rx_pin: 0
  baud_rate: 500000
stepper:
  - platform: tmc2209
    max_speed: 1500 steps/s
    acceleration: 1000 steps/s^2
    deceleration: 100000 steps/s^2
    config_dump_include_registers: true
    rsense: 220 mOhm
    vsense: False
    enn_pin: 8
    index_pin: 6
    diag_pin: 14
    on_stall:
      - stepper.stop: driver
# id(ropener_cover)->current_operation
# COVER_OPERATION_IDLE, COVER_OPERATION_OPENING, COVER_OPERATION_CLOSING
binary_sensor:
  - platform: gpio
    pin:
      number: 23
      mode: INPUT
      inverted: true
    filters:
      - delayed_on: 10ms
    on_multi_click:
      # --- Single Click ---
      - timing:
          - ON for at most 1.0s
          - OFF for at least 0.5s
        then:
          - if:
              condition: ## If moving, then stop
                lambda: 'return (id(ropener_cover).current_operation != COVER_OPERATION_IDLE);' # Should evaluate to TRUE if moving
              then:
                - cover.stop: ropener_cover
              else: ## If not moving, then close
                - cover.close: ropener_cover
      # --- Double Click ---
      - timing:
          - OFF for at most 0.3s
        then:
          - cover.open: ropener_cover
  - platform: gpio
    name: Open Limit Switch
    pin:
      number: 15
      mode: INPUT
      inverted: true
    on_press:
      then:
          position: 0
  - platform: gpio
    name: Close Limit Switch
    pin:
      number: 3
      mode: INPUT
      inverted: true
    on_press:
      then:
cover:
    has_position: true
    assumed_state: false
    lambda: "return 1.0 - (id(driver)->current_position / ${max_distance_steps});"
    stop_action:
    open_action:
      - stepper.set_target:
          target: 0
    close_action:
          target: !lambda return ${max_distance_steps};
    position_action:
          target: !lambda return (1.0 - pos) * ${max_distance_steps};```
Doesn’t look like the template cover ever sets the operation mode. You would need to do that yourself in the actions.
The problem is related to the cover position. When I was dividing two integers I would get a 0, and not a float like is required. So I just cast the position as a float and that’s fixed the tracking issue.
It’s still not working, even though I thought I had it. I’m even trying to set the operation manually in the cover and still no luck. It stays stuck in IDLE
Here are the logs while it’s moving:
14:05:26.494][D][main:246]: COVER open_action
[14:05:26.494][D][cover:147]: 'Glasscalibur' >>
[14:05:26.503][D][cover:150]:   Position: 0%
[14:05:26.503][D][cover:163]:   Current Operation: IDLE
[14:05:26.518][D][cover:147]: 'Glasscalibur' >>
[14:05:26.527][D][cover:150]:   Position: 0%
[14:05:26.528][D][cover:163]:   Current Operation: IDLE
Here’s the updated config:
substitutions:
  max_distance_steps: 371073 # converts cm to steps. Use this in remaining code
api:
  encryption:
    key: !secret api_key
ota:
  - platform: esphome
logger:
  level: VERBOSE
  hardware_uart: UART0
esp32:
  variant: esp32c6
  framework:
    type: esp-idf
wifi:
  on_connect:
    then:
      - logger.log: "Connected to WiFi! Running post-connect actions."
      - if:      # NEED TO CHECK IF EITHER LIMIT SWITCH IS PRESSED AND SET POSITION BASED ON THAT
          condition:
            binary_sensor.is_on: limit_switch_1  # Check if switch is pressed
          then:
            - logger.log: "SETTING LIMIT 1"
                position: ${max_distance_steps}
                target: ${max_distance_steps}
      - if:
          condition:
            binary_sensor.is_on: limit_switch_2  # Check if switch is pressed
          then:
            - logger.log: "SETTING LIMIT 2"
                position: 0
                target: 0
esphome:
  on_boot:
    # - priority: -100
    #   then:
      - logger.log: "CHECKING LIMIT SWITCHES"
          condition:
          then:
      - if:
          condition:
          then:
                position: 0
                target: 0
          direction: ccw
          microsteps: 8
          interpolation: true
          threshold: 50
      - tmc2209.currents:
          irun: 25 # 26 = 0.6A current. DO NOT EXCEED. MOTOR GETS STUPID HOT.
          ihold: 0
          tpowerdown: 0
          iholddelay: 0
output:
  - platform: ledc
    pin: GPIO5
uart:
  tx_pin: 1
  rx_pin: 0
  baud_rate: 500000
stepper:
  - platform: tmc2209
    #max_speed: 1500 steps/s # Faster speed is louder #2000 good. #1500 great
    max_speed: 1501 steps/s # Faster speed is louder #2000 good. #1500 great
    deceleration: 100000 steps/s^2 # Stop very fast in case limit swith reached
    rsense: 220 mOhm
    vsense: False
    enn_pin: 8
    index_pin: 6
    diag_pin: 14
    #on_stall:
      #- stepper.stop: driver
binary_sensor:
  - platform: gpio
    pin:
      number: 23
      mode: INPUT
      inverted: true
    filters:
      - delayed_on: 10ms
    on_multi_click:
      - timing:
        then:
          - cover.close: glasscalibur_cover
          - if:
                lambda: return (id(glasscalibur_cover).current_operation != COVER_OPERATION_IDLE); # Should evaluate to TRUE if moving
              then:
                - cover.stop: glasscalibur_cover
      - timing:
        then:
          - cover.open: glasscalibur_cover
  - platform: gpio
    pin:
      number: 15
      mode: INPUT
      inverted: true
    interrupt_type: FALLING
    filters:
      - delayed_on: 10ms
    on_press:
      then:
      - logger.log: "LIMIT 1 PRESSED"
      - cover.template.publish:
          position: 1.0
  - platform: gpio
    pin:
      number: 3
      mode: INPUT
      inverted: true
    # Optional: filters to prevent noise from triggering the sensor
    filters:
      - delayed_on: 10ms
    on_press:
      then:
      - logger.log: "LIMIT 2 PRESSED"
          position: 0
          target: 0
          position: 0
cover:
    has_position: true
    lambda: "return (float(id(driver)->current_position) / float(${max_distance_steps}));"
    stop_action:
      - logger.log: "COVER stop_action"
    open_action:
      - logger.log: "COVER open_action"
          current_operation : OPENING
    close_action:
      - logger.log: "COVER close_action"
          target: 0
    position_action:
      - logger.log: "COVER position_action"
          target: !lambda return pos * ${max_distance_steps};
    on_opening:
      - logger.log: "COVER Opening"
    on_opened:
      - logger.log: "COVER Open"
          current_operation : IDLE
    on_closing:
      - logger.log: "COVER Closing"
          current_operation : CLOSING
    on_closed:
      - logger.log: "COVER Closed"
