Cover (MDT actor) moves not in position when it is closed before
Hi at all,
I am using MDT jalousieactors and try to get a automation running. I am using the covers until now only with open and close, not to set a position.
I created an automation, which opens the cover when it detects a motion and the lux is higher then 300 outside and shut off the light when its on. My automation is this:
alias: EG-BAD - Rolladen bei Helligkeit öffnen
description: ""
triggers:
  - trigger: state
    entity_id:
      - binary_sensor.prasenz_hlk_pm_eg_bad_decke
    to:
      - "on"
conditions:
  - condition: and
    conditions:
      - condition: time
        after: "07:00:00"
        before: "12:00:00"
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
          - sat
          - sun
      - condition: numeric_state
        entity_id: sensor.dammerung_lux_ws_dg_aussen_jung_2225
        above: 300
      - condition: state
        entity_id: cover.rolladen_eg_bad_fenster
        state:
          - closed
actions:
  - if:
        entity_id: sensor.temperatur_pt1000_eg_aussen_nordseite_erker
        below: 2
    then:
      - parallel:
          - action: cover.set_cover_position
            metadata: {}
              position: 90
          - if:
              - condition: state
                entity_id: light.stripe_dusche_nische_eg_bad
                state:
                  - "on"
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 7
                  milliseconds: 0
              - action: light.turn_off
                metadata: {}
                data: {}
          - if:
              - condition: state
                entity_id: light.stripes_klo_eg_bad
                state:
                  - "on"
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 7
                  milliseconds: 0
                metadata: {}
                data: {}
    else:
      - parallel:
          - action: cover.open_cover
            metadata: {}
            data: {}
          - if:
              - condition: state
                state:
                  - "on"
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 7
                  milliseconds: 0
                metadata: {}
                data: {}
          - if:
              - condition: state
                state:
                  - "on"
            then:
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 7
                  milliseconds: 0
                metadata: {}
                data: {}
  - action: automation.turn_off
    metadata: {}
      entity_id: automation.eg_bad_rolladen_bei_helligkeit_offnen
      stop_actions: false
mode: single
My problem is now, when motion is detected and it is under 2 grad celsius, the cover should go to 90%. HA shows, that the cover moves to 90% but the cover does noting. When I try to go to some percentage in HA visu, the cover does also not move a bit.
When the cover is open and I try to get to 90%, that everything is working fine. It does not work only when the cover is closed before, then I am not able to go to a percentage position. When it is more the 2 grad celsius, the cover goes to open without any problems.
What could be the problem?
Greetings
Martin
Just figured out, that it is not a problem with HA, it is a problem with the actor. KNX native doesn’t work either.
Sorry, found the problem after 3 hours :frowning:
In my actor was for every cover the option “extended lockfunction” enabled, but nothing else configured. After disabling, everythings works fine now :slight_smile:
Sorry again for the post
