I have a cover ( Garage Door) set up on Hassio and is working fine through Hassio.
HomeBrdige plugin is configured and is working fine for switches, motion, temp etc. However, the cover is not appearing in homebridge ( not available on IOS Home). I am not seeing any errors in the log relating to it either. Not sure what is wrong
my set up is
"log_level": "info",
"avahi_interfaces": "",
"avahi_hostname": "",
"avahi_domainname": "local",
"enable_ipv6": true,
"packages": [],
"init_commands": [],
"plugins": []
and config.json
“bridge”: {
“name”: “Home Assistant”,
“username”: “CC:22:3D:AE:CE:30”,
“port”: 51826,
“pin”: “686-71-170”
“description”: “Homebridge for Home Assistant”,
“accessories”: [],
“platforms”: [
“platform”: “HomeAssistant”,
“name”: “HomeAssistant”,
“host”: “https://XXXXXXX.duckdns.org”,
“password”: “XXXXXXX”,
“default_visibility”: “visible”,
“supported_types”: [
“binary_sensor”,
“climate”,
“cover”,
“fan”,
“input_boolean”,
“light”,
“lock”,
“scene”,
“sensor”,
“switch”
“logging”: true
thanks
