Right, doesn’t look good in a single line of code…
Exception in async_discover when dispatching 'mqtt_discovery_new_cover_mqtt': ({'availability': [{'topic': 'zigbee2mqtt/bridge/state'}], 'command_topic': 'zigbee2mqtt/Projector Screen/set', 'device': {'identifiers': ['zigbee2mqtt_0x5c0272fffec3d6de'], 'manufacturer': 'Lonsonho', 'model': 'Curtain/blind motor controller (QS-Zigbee-C01)', 'name': 'Projector Screen', 'sw_version': 'Zigbee2MQTT 1.18.1'}, 'json_attributes_topic': 'zigbee2mqtt/Projector Screen', 'name': 'Projector Screen', 'position_topic': 'zigbee2mqtt/Projector Screen', 'set_position_template': '{ "position": {{ position }} }', 'set_position_topic': 'zigbee2mqtt/Projector Screen/set', 'unique_id': '0x5c0272fffec3d6de_cover_zigbee2mqtt', 'value_template': '{{ value_json.position }}', 'platform': 'mqtt'},)
Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable return schema(data)
File "/usr/src/homeassistant/homeassistant/components/mqtt/cover.py", line 118, in validate_options raise vol.Invalid( voluptuous.error.Invalid: 'value_template' must be set together with 'state_topic'.
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 160, in async_discover config = schema(discovery_payload)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__ return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 341, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 337, in _exec v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 276, in __call__ raise er.MultipleInvalid([e]) voluptuous.error.MultipleInvalid: 'value_template' must be set together with 'state_topic'.
I hope now it’s more user friendly.
"value_template’ must be set together with “state_topic”
How this can break on its own? I mean should I try to upgrade the z2m integration or the HA core (I have it at 2021.6.5) or just remove the device and try to add it again? Any tips appreciated.
