Since moving to ESPHOME 2026.4.x I get a crash and rollback if the following line is included, can anyone please help. My YAML has been working for some time, though a recent ESPHome update required that I move a Map out of the Lambda and into YAML. Now this is crashing the display:
Thank you for your suggestion. Unfortunately it did not resolve the issue. It is very odd that this one line is blowing things out since the uplift to 2026.4. I wonder what changed.
Actually it is some other instability, I have fairly reliably been able to compile and run the code without that line, but since I added your code I have now tried 4 times with bits removed and now back to what I had that was working and every time it is crashing on boot.
It is also taking a very long time to boot, so I think it is actually crashing and re-tryig on the working version of 2026.4 that I have installed and runs fine.
All fixed now that I have updated to 2026.5.0. No more boot crashes and I have re-compiled and uploaded 5 times with various adjustments around that line of code and others, just to see if I could break it.
