Crashed and restoring previous backup results in the same. Help with diagnosing.
Last thursday I got a notification that my HomeAssistant disconnected. I could not get the UI to load up, always timed out. I played around with several different things before giving up and repaving with HAOS again and restoring a backup from 2 days before the random crash. No luck, looked like it worked and then the UI stopped responding again right away.
RaspberryPi 5 with an external SSD via usb, been running HomeAssistant for over a year without any issues until now.
I can connect via SSH, and if I run ha core restart everything will come up for about a minute, and then the UI becomes unresponsive again. I've commented out almost all of my automations. I've unplugged my z-wave and zigbee devices from the pi. Though as you will see there are still some errors in the core logs.
Looking for some help in how to track down what is suddenly taking my system down. The ssh stays connected consistently, so doesn't feel like a problem with the hardware.
Latest core logs:
s6-rc: info: service legacy-services: stopping
s6-svwait: fatal: timed out
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Exception ignored while trying to write to the signal wakeup fd:
  File "/usr/local/lib/python3.14/asyncio/unix_events.py", line 39, in _sighandler_noop
    def _sighandler_noop(signum, frame):
BlockingIOError: [Errno 11] Resource temporarily unavailable
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2026-05-07 17:34:13.656 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-05-07 17:34:13.657 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration plant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-05-07 17:34:13.658 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-05-07 17:34:13.658 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration openplantbook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-05-07 17:34:31.632 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration 'bluetooth_tracker' not found.
2026-05-07 17:34:31.728 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2026-05-07 17:34:31.792 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=163 from 2026-05-07 21:25:59.751858)
2026-05-07 17:34:33.320 ERROR (MainThread) [homeassistant.config] Platform error: device_tracker - Integration 'bluetooth_tracker' not found.
2026-05-07 17:34:33.870 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for ring integration could not authenticate: Authentication error communicating with Ring API
2026-05-07 17:34:34.419 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to set the Z-Wave JS app options: App core_zwave_js has invalid options: Device '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00' does not exist in Z-Wave JS (core_zwave_js). Got {'s0_legacy_key': 'DE17FD8856F6A3993B58E6775F08CD98', 's2_access_control_key': 'C27DE44D7F368A6C3A629664C5CC54E6', 's2_authenticated_key': 'DC2ECB95DABEF8A994AB27C7285DECF8', 's2_unauthenticated_key': '197C0D9F365562A235602CB662294B74', 'device': '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00', 'lr_s2_access_control_key': 'A48CEF01B6A3584BC8899D6FB0DEF75F', 'lr_s2_authenticated_key': '59E20C30CF8D18CCB8B74F385794C14A'}
2026-05-07 17:34:35.924 WARNING (zeroconf-ServiceBrowser-_googlecast._tcp-120) [pychromecast.dial] Failed to determine cast type for host <unknown> (<urlopen error [SSL: UNEXPECTED_EOF_WHILE_READING] EOF occurred in violation of protocol (_ssl.c:1081)>) (services:{MDNSServiceInfo(name='start.ca-IPBS9510-104f10c97021d234ea9f2b60138ea37f._googlecast._tcp.local.')})
2026-05-07 17:34:37.147 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for apollo-msr-2-b2249c @ 192.168.184.226: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.184.226', port=6053))]: [Errno 111] Connect call failed ('192.168.184.226', 6053) (SocketAPIError)
2026-05-07 17:34:44.551 WARNING (MainThread) [custom_components.hacs] You have 'LAB02-Research/HASS.Agent-Integration' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Repository has been abandoned)
2026-05-07 17:34:45.029 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to set the Z-Wave JS app options: App core_zwave_js has invalid options: Device '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00' does not exist in Z-Wave JS (core_zwave_js). Got {'s0_legacy_key': 'DE17FD8856F6A3993B58E6775F08CD98', 's2_access_control_key': 'C27DE44D7F368A6C3A629664C5CC54E6', 's2_authenticated_key': 'DC2ECB95DABEF8A994AB27C7285DECF8', 's2_unauthenticated_key': '197C0D9F365562A235602CB662294B74', 'device': '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00', 'lr_s2_access_control_key': 'A48CEF01B6A3584BC8899D6FB0DEF75F', 'lr_s2_authenticated_key': '59E20C30CF8D18CCB8B74F385794C14A'}
Latest Supervisor Logs
2026-05-07 17:30:07.667 ERROR (MainThread) [supervisor.misc.tasks] Watchdog missed 2 Home Assistant Core API responses in a row. Restarting Home Assistant Core!
2026-05-07 17:30:07.676 INFO (MainThread) [supervisor.docker.manager] Restarting homeassistant
2026-05-07 17:31:13.030 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
2026-05-07 17:32:17.669 INFO (MainThread) [supervisor.api.middleware.security] /addons access from de91e161_hassio_onedrive_backup
2026-05-07 17:32:48.671 INFO (MainThread) [supervisor.api.middleware.security] /backups/new/full access from de91e161_hassio_onedrive_backup
2026-05-07 17:32:48.674 INFO (MainThread) [supervisor.backups.manager] Backup 9e3949e8 starting stage addon_repositories
2026-05-07 17:32:48.674 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug 9e3949e8
2026-05-07 17:32:48.676 INFO (MainThread) [supervisor.backups.manager] Backup 9e3949e8 starting stage home_assistant
2026-05-07 17:34:11.096 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2026-05-07 17:34:11.096 ERROR (MainThread) [supervisor.homeassistant.module] Preparing backup of Home Assistant Core failed. Failed to inform HA Core: Connection was closed.
2026-05-07 17:34:11.105 ERROR (MainThread) [supervisor.backups.manager] Backup 9e3949e8 error: Preparing backup of Home Assistant Core failed. Failed to inform HA Core: Connection was closed.
2026-05-07 17:34:11.116 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
2026-05-07 17:34:11.125 WARNING (MainThread) [supervisor.homeassistant.websocket] Can't send WebSocket command: Can't connect to Home Assistant Core WebSocket, the API is not reachable
2026-05-07 17:34:11.126 WARNING (MainThread) [supervisor.homeassistant.websocket] Can't send WebSocket command: Can't connect to Home Assistant Core WebSocket, the API is not reachable
2026-05-07 17:34:11.127 WARNING (MainThread) [supervisor.homeassistant.websocket] Can't send WebSocket command: Can't connect to Home Assistant Core WebSocket, the API is not reachable
2026-05-07 17:34:11.128 WARNING (MainThread) [supervisor.homeassistant.websocket] Can't send WebSocket command: Can't connect to Home Assistant Core WebSocket, the API is not reachable
2026-05-07 17:34:11.292 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2026-05-07 17:34:11.295 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
2026-05-07 17:34:11.300 WARNING (MainThread) [supervisor.homeassistant.websocket] Can't send WebSocket command: Can't connect to Home Assistant Core WebSocket, the API is not reachable
2026-05-07 17:34:32.609 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2026-05-07 17:34:32.698 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-05-07 17:34:36.355 INFO (MainThread) [supervisor.homeassistant.api] Connected to Core via TCP http://172.30.32.1:8123
2026-05-07 17:34:36.355 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2026-05-07 17:34:46.374 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2026-05-07 17:34:46.374 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2026-05-07 17:35:48.172 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
2026-05-07 17:36:13.026 INFO (MainThread) [supervisor.api.middleware.security] /backups access from de91e161_hassio_onedrive_backup
2026-05-07 17:36:53.406 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
What more can I provide? What can I try? What can I check?
Thanks for the help.
