Crashes after some time (fatal write error)
After some time, webinterface is not available. i need to restart hass process. any ideas?
configuration: raspi3, homematic, hue, harmony - no custom components.
process seems to be running:
root@raspberrypi:/home/pi/.homeassistant# ps uax | grep hass
pi 4158 0.2 4.4 125556 42488 ? Sl Jan16 5:02 /usr/bin/python3 /usr/local/bin/hass --open-ui
last lines from homeassistent.log
17-01-16 20:13:12 pyhomematic.devicetypes.generic: HMGeneric.getValue: WORKING on LEQ121****:4 Exception: <Fault -1: ‘Failure’>
17-01-16 20:13:12 pyhomematic.devicetypes.generic: HMGeneric.getValue: STATE on LEQ121****:4 Exception: <Fault -1: ‘Failure’>
17-01-16 20:13:18 netdisco.ssdp: Error fetching description at 192.168.2.140
17-01-16 20:30:15 homeassistant.core: Error doing job: Fatal write error on socket transport
File “/usr/lib/python3.4/asyncio/selector_events.py”, line 620, in write
n = self._sock.send(data)
OSError: [Errno 113] No route to host
last lines from “console”:
ERROR:homeassistant.core:Error doing job: Task exception was never retrieved
File “/usr/lib/python3.4/asyncio/tasks.py”, line 237, in _step
result = next(coro)
File “/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py”, line 207, in async_update_ha_state
“No entity id specified for entity {}”.format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity LEQ066****
result = next(coro)
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity LEQ066**** POWER
result = next(coro)
result = next(coro)
INFO:homeassistant.core:Starting Home Assistant core loop
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
INFO:homeassistant.core:Timer:starting
netstat
pi@raspberrypi:~ $ netstat -plant
(Es konnten nicht alle Prozesse identifiziert werden; Informationen über
nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
Aktive Internetverbindungen (Server und stehende Verbindungen)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 192.168.2.111:2015 0.0.0.0:* LISTEN 19873/node-red
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN -
tcp 0 0 192.168.2.111:40525 0.0.0.0:* LISTEN 17198/raumsrvDaemon
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 17198/raumsrvDaemon
tcp 0 0 127.0.0.1:28017 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 19873/node-red
tcp 9 0 192.168.2.111:8123 192.168.2.114:60582 CLOSE_WAIT 4158/python3
tcp 0 0 192.168.2.111:46942 195.154.179.238:443 TIME_WAIT -
tcp 0 0 192.168.2.111:60886 195.154.172.147:443 TIME_WAIT -
tcp 0 0 192.168.2.111:60888 195.154.172.147:443 TIME_WAIT -
tcp 0 0 192.168.2.111:46966 195.154.179.238:443 TIME_WAIT -
tcp 0 0 192.168.2.111:46964 195.154.179.238:443 TIME_WAIT -
tcp 0 0 192.168.2.111:60870 195.154.172.147:443 TIME_WAIT -
tcp 0 0 192.168.2.111:2015 192.168.2.222:43687 VERBUNDEN 19873/node-red
tcp 0 0 192.168.2.111:35456 192.168.2.222:80 TIME_WAIT -
tcp 0 0 192.168.2.111:35458 192.168.2.222:80 TIME_WAIT -
tcp 0 0 127.0.0.1:55456 127.0.0.1:27017 VERBUNDEN 19873/node-red
tcp 0 0 192.168.2.111:60402 192.168.2.140:47181 TIME_WAIT -
tcp 0 0 127.0.0.1:27017 127.0.0.1:55462 VERBUNDEN -
tcp 0 0 192.168.2.111:48378 199.16.156.48:443 VERBUNDEN 19873/node-red
tcp 0 0 192.168.2.111:59846 192.168.2.140:8009 VERBUNDEN 4158/python3
tcp 0 0 127.0.0.1:27017 127.0.0.1:55456 VERBUNDEN -
tcp 0 0 192.168.2.111:33896 192.168.2.140:38994 TIME_WAIT -
tcp 0 0 192.168.2.111:38884 192.168.2.140:51116 TIME_WAIT -
tcp 0 0 127.0.0.1:27017 127.0.0.1:55458 VERBUNDEN -
tcp 0 0 192.168.2.111:22 192.168.2.114:65428 VERBUNDEN -
tcp 0 0 192.168.2.111:46938 195.154.179.238:443 TIME_WAIT -
tcp 0 0 192.168.2.111:58984 192.168.2.140:8008 VERBUNDEN 4158/python3
tcp 0 0 192.168.2.111:60866 195.154.172.147:443 TIME_WAIT -
tcp 0 0 192.168.2.111:38862 192.168.2.140:51116 TIME_WAIT -
tcp 0 0 192.168.2.111:60872 195.154.172.147:443 TIME_WAIT -
tcp 0 0 192.168.2.111:46958 195.154.179.238:443 TIME_WAIT -
tcp 0 0 192.168.2.111:58980 192.168.2.140:8008 VERBUNDEN 4158/python3
tcp 0 0 192.168.2.111:60882 195.154.172.147:443 TIME_WAIT -
tcp 0 0 127.0.0.1:55458 127.0.0.1:27017 VERBUNDEN 19873/node-red
tcp 0 4560 192.168.2.111:22 192.168.2.114:60576 VERBUNDEN -
tcp 0 0 192.168.2.111:52804 192.168.2.222:2001 TIME_WAIT -
tcp 0 0 127.0.0.1:27017 127.0.0.1:55460 VERBUNDEN -
tcp 0 0 127.0.0.1:55462 127.0.0.1:27017 VERBUNDEN 19873/node-red
tcp 0 0 192.168.2.111:46948 195.154.179.238:443 TIME_WAIT -
tcp 0 0 127.0.0.1:55460 127.0.0.1:27017 VERBUNDEN 19873/node-red
tcp 0 0 192.168.2.111:59842 192.168.2.140:8009 VERBUNDEN 4158/python3
tcp 0 0 192.168.2.111:50278 192.168.2.222:2001 VERBUNDEN 4158/python3
tcp 0 0 192.168.2.111:40525 192.168.2.140:34355 TIME_WAIT -
tcp 0 0 192.168.2.111:57118 192.168.2.140:47365 VERBUNDEN 17198/raumsrvDaemon
tcp6 0 0 :::22 :::* LISTEN -
Do you have any devices called LEQ066 or has that in the name? From the log that seems to be the thing that pops up the most.
If you have a component with an entity ID just try commenting it out and reloading again :slight_smile:
In the errors the trace looks like that missing entity is causing a proper error. Its worth a go
thanks, i´ll check later this week… and answer if this fixes my problem
