Hi everybody,
my Home Server crashed a couple of days ago. Luckily, I had a “full” backup, or so I thought. Home Assistant
ran as a docker
container, and the entire directory linked to Home Assistant was a git
repository stored on my local git server (including .storage
and .cloud
Now I installed hass on a spare raspberry pi 4
, because the server has to be repaired. I installed docker
and docker-compose
, copied my backup, then ran docker-compose up -d
on the compose file.
Home Assistant started. However! I am missing the following things - at least those, they were what I noticed instantly. Perhaps there is more
tokens
created by my user - all my
areas
that I manually created - all
integrations
, for exampleWLED
devices, alltasmota
devices added viamqtt
,zigbee2mqtt
hacs
integration
Also, everything HACS
related was missing. The hacs
folder is part of this hass root folder that I backed up. So I thought at the most I’d have to re-install hacs
, it would recognize the settings (github token, installed integrations), and run. But I had to manually do all this.
As I am currently manually re-installing everything, anyway, it is too late. But I’d like to have a complete backup when switching back to my Home Server once possible. What do you suggest I do?
Where are files saved other than in the hass root directory, that I’d need to include in my backups from now on?
Thank you in advance for your support
