joakimpet
(Joakimpet)
June 19, 2023, 1:28pm
1
Hi!
I am trying to create a template sensor that subtracts one from the other and one of them is derrived from my solar panels.
- platform: rest
resource: http://192.168.1.35:8484/getdevdata.cgi?device=2&sn=SP001260322C0277
scan_interval: "00:00:10"
device_class: energy
value_template: "{{ value_json.pac | float / 1000 | round(2) }}"
unit_of_measurement: "kW"
and another api sensor sensor.power_production_trollslandevagen_3
But when i use developer tools>templates and put the first sensor in
{{ states('sensor.solar_realtime_kW') }}
I get an unknown result. and
but in when looking at the sensor in entities it gives me the readout.
What am i missing?
Entity IDs are always slugs, so they will never contain uppercase letters:
{{ states('sensor.solar_realtime_kw') }}
Also, keep in mind that states are always strings, so if you are going to perform mathematical operations on them you will need to convert them to a numeric data type.
{{ states('sensor.solar_realtime_kw') | float(0) - states('sensor.power_production_trollslandevagen_3') | float(0) }}
tom_l
June 19, 2023, 1:48pm
3
You don’t need to add the sensor domain to the name either, home assistant will do that for you.
This:
name: Solar Realtime kW
Will create the entity id, sensor.solar_realtime_kw
joakimpet
(Joakimpet)
June 20, 2023, 9:18am
4
Yes that was the problem.
No i know not to name the sensor sensor:)
Thank you!
