Create blueprint with template as input and trigger
I’m trying to create a blueprint that has a template as input, and is also triggered when this template is changed.
I created this, but doesn’t seem to trigger
blueprint:
  domain: automation
  input:
    input_template:
      selector:
        template:
    value_template: !input input_template
  - service: notify.html5_laptop
      message: triggered
Triggers only work on a subset of template / jinja commands because the automation is not actually running until after the trigger happens. You would need to make sure that what you put there are things it can do.
I have not tried this as the user would be more likely to break the automation rather than get it to work.
I suggest you writing the template, and use one of the other selectors to plug in a value to an entity or something to prevent mis-coding problems.
Should you with to pursue this, make sure the template is checked to work or the blueprint might break and become unavailable to the UI.
