Create Group -Mapping Values Not Found
  LightDownstairs
    - name: Downstairs
        entities:
          - light.1f_kitchen_stove_east
          - light.1f_lc_living_room_south
          - light.1f_lc_living_room_east
          - light.1f_lc_living_room_hallway
          - light.1f_livingroom_3_head_lamp_bot
          - light.1f_livingroom_3_head_lamp_top
          - light.1f_livingroom_3_head_lamp_mid
   LightUpstairs
     - name: Upstairs
         entities:
           - light.2f_bedroom_lamp
           - light.2f_bedroom_lamp_mid
           - light.2f_bedroom_lamp_top
           - light.2f_bedroom_mini_lamp
           - light.2f_lc_bedroom_bay_window
           - light.2f_lc_living_room_east
           - light.2f_lc_living_room_se
           - light.2f_lc_work_area_north
           - light.2f_work_overhead_area
Getting this error.
General Errors:
- Error loading /home/homeassistant/.homeassistant/configuration.yaml: mapping values are not allowed here
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 6, column 11
Are the hyphens in the right place? Only thing Ican think of is wrong but every example I’ve seen online seems to follow this format.
Entities should be inline with name. There should be no dash in front of name.
Look at the examples:
Oooof. Man that’s an oversight. Thanks!
So I fixed that and now I’m getting this error code
  group:
    - Invalid config for [group]: value should be a string for dictionary value @ data['group']['lightdownstairs']['entities']. Got None
value should be a string for dictionary value @ data['group']['lightupstairs']['entities']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 4). Please check the docs at https://home-assistant.io/components/group/
    - default_config: ?
      group: [source /home/homeassistant/.homeassistant/configuration.yaml:4]
        lightdownstairs: [source /home/homeassistant/.homeassistant/configuration.yaml:5]
          - entities: [source /home/homeassistant/.homeassistant/configuration.yaml:7]
        lightupstairs: [source /home/homeassistant/.homeassistant/configuration.yaml:16]
          - entities: [source /home/homeassistant/.homeassistant/configuration.yaml:18]
      script: ?
Here’s the modified script compensating for the misaligned entities
That still looks nothing like the example.
Whoops. Pasted the error message when I meant to paste the code.
group:
  lightdownstairs:
    - name: Downstairs
      entities:
  lightupstairs:
    - name: Upstairs
      entities:
That’s the edited code. The above post is the error code
I guess I’ll try…
Here is yours:
group:
  lightdownstairs:
    - name: Downstairs
      entities:
  lightupstairs:
    - name: Upstairs
      entities:
Here is how it looks in the example ion the docs that Tom linked to above:
group:
  kitchen:
    entities:
      - switch.kitchen_pin_3
  climate:
    entities:
      - sensor.bedroom_temp
      - sensor.porch_temp
hopefully you can see the difference.
Yes! I do.
Thanks so much. Fixed!
Sorry, I’ve been known to rush thing when I"m excited about new projects. Need to remember to slow down…
