For our new house i need to create alot of helpers (lightgroups).
For example our bedroom:
I have 16 GU10 light bulbs for which i created the following helpers manually.
Plafondspots light.plafondspots
Plafondspots - raam links light.plafondspots_raam_links
Plafondspots - raam rechts light.plafondspots_raam_rechts
Plafondspots - ramen light.plafondspots_ramen
Plafondspots - wand inloopkast light.plafondspots_wand_inloopkast
Plafondspots - wand inloopkast links light.plafondspots_wand_inloopkast_links
Plafondspots - wand inloopkast rechts light.plafondspots_wand_inloopkast_rechts
Wandspots - links tv light.wandspots_links_tv
Wandspots - links tv - links light.wandspots_links_tv_links
Wandspots - links tv - rechts light.wandspots_links_tv_rechts
Wandspots - rechts tv light.wandspots_rechts_tv
Wandspots - rechts tv - links light.wandspots_rechts_tv_links
Wandspots - rechts tv - rechts light.wandspots_rechts_tv_rechts
Wandspots - tv light.wandspots_tv
I have 16 more rooms/area’s to go, mistakes are made easily.
Is there any scripted way to create my helpers?
create a file
groups_lights.yaml
add it to your configuration yaml if you dont have it with
group: !include groups_lights.yaml
in the group_lights.yaml define all your light groups
celing-lights:
entities:
- light.plafondspot_1
- light.plafondspot_2
- light.plafondspot_3
- light.plafondspot_4
plafondspots_raam_links:
name: Plafondspots - Raam Links
entities:
and so on untill you add all
restart and you will load those
do you know how to use python?
you can do python script to make your yaml code
import yaml
# Example data structure:
groups = {
"plafondspots": ["light.plafondspot_1", "light.plafondspot_2", "light.plafondspot_3"],
"plafondspots_raam_links": ["light.plafondspot_1", "light.plafondspot_2"],
"wandspots_links_tv": ["light.wandspot_1", "light.wandspot_2"],
output = []
for group_name, entities in groups.items():
output.append({
"platform": "group",
"name": group_name.replace("_", " ").title(),
"unique_id": group_name,
"entities": entities
print(yaml.dump(output, sort_keys=False))
and the output past it on you light: section in your configuration.yaml
remember to Check configuration before reboot
thanks, i thought about using yaml (i used to do it like that in the early days). But i changed to helpers due to the better integration within HA. Thats why i was hoping i could create helpers with a script. Cause as far as i understand it correctly a group in the configuration.yaml file isnt the same a “helper group”
i dont think is possible to make a bulk of helpers , but i can be wrong
Maybe using rest api
i find this
import requests
# Home Assistant URL (no trailing slash)
BASE_URL = "http://homeassistant.local:8123" # Change to your instance
TOKEN = "YOUR_LONG_LIVED_ACCESS_TOKEN" # Paste your token here
HEADERS = {
"Authorization": f"Bearer {TOKEN}",
"Content-Type": "application/json",
def create_input_boolean(object_id, name, icon="mdi:toggle-switch"):
url = f"{BASE_URL}/api/config/input_boolean/config/{object_id}"
payload = {
"name": name,
"icon": icon,
"initial": False
response = requests.post(url, json=payload, headers=HEADERS)
if response.status_code == 200:
print(f"Created {object_id}")
else:
print(f"Failed to create {object_id}: {response.status_code} {response.text}")
def main():
count = 10 # Adjust how many helpers to create
for i in range(1, count + 1):
object_id = f"auto_boolean_{i}"
name = f"Auto Boolean {i}"
create_input_boolean(object_id, name)
if __name__ == "__main__":
main()
this is for boolean you can try with lights
edit *********************
wait there is not light on helpers , you cant create a light helper the only option is with template
yaml
You’ll get better results generating YAML file as packages.
I create “templates” outside of HA. These contains sensor templates, automations, input numbers, alerts, displays, etc. Then use a shell script to replicate into HA.
95% of my config and UI across two houses is created this way.
