In preparation for the holiday season, I’m thinking to buy a few Zigbee smart plugs to automate my different Christmas lights. I want to be able to use the smart plugs for something else at different times of the year.
So far, I had 1 smart plug that I used either for my Christmas tree lights OR to plug in my WiFi extender, so I have better WiFi in the garden. I created an input_select
helper to tell Home Assistant what was plugged into the smart plug and then based my automations on the state of this helper. This works great with 1 smart plug.
Now I want to add a bunch of smart plugs for different Christmas lights in- and outside the house AND be able to use the plugs for different use-cases outside the holiday period.
I’ve investigated creating a dynamic group and was partially successful as it creates a group of the input_select
helpers if it contains the word ‘Kerst’. I wasn’t able to group the actual smart plug switches. I can’t get the group to contain the lights, while basing the selection criteria on the input_select
helpers:
alias: Group Kerstverlichting
description: >-
Create a group for all Christmas lights (inlcuding Christmas tree) plugged
into a Smart Plug (identified through 'input_select' helpers)
- platform: state
entity_id:
- input_select.hue_smart_plug
condition: []
- service: group.remove
object_id: kerstverlichting
- service: group.set
icon: mdi:string-lights
entities: >
{{ states.input_select | selectattr('state', 'search', 'Kerst') |
map(attribute='entity_id') | join(', ') }}
mode: single
- Is there a better way than using
input_select
helpers? - If
input_select
helpers are the right approach: how do I dynamically create the group of smart plugs that have Christmas lights plugged into them?
Thanks for any suggestions or help!
