Create long lived access token with hass --script auth?
using the embedded auth script hass --script auth it’s possible to create a user/password for auth without having home assistant running.
is it possible to do this with a long lived access token? i’d like to create one via command line instead of having to start HA and go through the UI to create the token.
Nope.
/homeassistant/scripts   dev  ls -1         ✔  3362  11:22:35
auth.py
benchmark
check_config.py
credstash.py
ensure_config.py
__init__.py
keyring.py
macos
__pycache__
