Create restore scene of group of entities
hi so i have tried 2 different scripts 2nd one i found searching
1st One
sequence:
  - action: scene.create
    metadata: {}
      scene_id: led_light_current_leds_state
      snapshot_entities:
        - group.wled_devices_save_restore_settings
alias: LED - LIGHT - CURRENT STATE
description: ""
2nd One
sequence:
    metadata: {}
      snapshot_entities: {{ state_attr('group.wled_devices_save_restore_settings', 'entity_id') }}
description: ""
now the first one runs but it doesnt record properly as when it restores. it will restore WLED Presets as blanks and down the road screws up
the 2nd one when i execute in node red. tells me it can pass None…or something like that… so its not recording every single entity correctly
i also tried using
in the entity states but it does nothing also…
so how do you properly create a scene of all the entites that are in the group
the restore is
sequence:
  - action: scene.turn_on
    metadata: {}
    data: {}
      entity_id: scene.led_light_current_leds_state
alias: LED - LIGHT - RESTORE STATE
description: ""
The template in your second example is missing outer quotes.
Rule #1 from Important Template Rules:
You must surround single-line templates with double quotes (") or single quotes (').
snapshot_entities: "{{ state_attr('group.wled_devices_save_restore_settings', 'entity_id') }}"
ah ok ya i added the qoutes and i dont get the error… and seems to be working… it didnt wanna work first few times i had to set them to power off presets then run the tests a few times seems like residual
so i hope it will hold
how do you know when you gotta use qoutes and when not
@123 so that one solved it… now my other one doesnt work i get
Entity IDs cannot be None for dictionary value @ data['snapshot_entities']
HomeAssistantError: Entity IDs cannot be None for dictionary value @ data['snapshot_entities']
    at p (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/errors/inputErrorHandler.js:1:1032)
    at m (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/errors/inputErrorHandler.js:1:1318)
    at C.#t (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/controllers/InputOutputController.js:1:1340)
in node red
my script is
sequence:
    metadata: {}
      scene_id: incoming_call_current_leds_state
      snapshot_entities: "{{ state_attr('wled_devices_save_restore_settings', 'entity_id') }}"
  - action: select.select_option
    metadata: {}
      option: Incoming Call
      entity_id: |
        {{ state_attr('group.wled_devices_incoming_call_presets', 'entity_id') }}
  - delay:
      hours: 0
      minutes: 0
      seconds: 20
      milliseconds: 0
    metadata: {}
    data: {}
      entity_id: scene.incoming_call_current_leds_state
alias: LED - "INCOMING CALL" - CURRENT STATE/RESTORE
description: ""
what is wrong with this?
never mind i found it… i didnt have group. on front
ugh my dyslexia really sucks i didnt notice it
Glad to hear it solved the problem.
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which indicates to others that the topic has been solved. This helps other users find answers to similar questions.
@123 ah ok did it work??? i checked it… and how do you know when to use quotations and what not to
so far ive used it mostly in templates when studio editor complains and i put quotes…
but how do you know when and when you dont need to?
Review Template Rule #1.
If you create a multiline template then you don’t need to wrap the template in quotes.
snapshot_entities: |
The vertical bar symbol | indicates the template begins on the next line. You can also use the greater than symbol > instead of |.
@123 ah ok ill try to remember that for the future… always learning…
