I would like to manually add sensor data from my central heating.
Every now and then I would change the temperature on my central heating unit manually and at the same time I would add that temperature to HA as well.
My thinking is I can then use that temperature in the same way as I am using the other real sensors in and around the house and integrate it into graphs, showing these several temperatures and also use the central heating temperature.
Looking around I saw a template that seemed to do what I want (slightly changed for my purpose), but I am missing the knowledge to get it to work.
template:
- trigger:
- platform: time_pattern
# This will update every 1 minute
minutes: "/1"
- sensor:
- name: "cv_temperature"
state: 42
unit_of_measurement: "temperature"
The idea being this would create sensor data every minute for the value that my central heating now has, 42.
What steps do I need to take to get this working?
I tried to create a helper but was stopped while doing that because I needed to supply a device, but I don’t have that in HA for the central heating.
My central heating has no endpoint where I can request the current target temperature. Hence trying to do this manually.
Beginner level HA user.
