Create sensor from external IP
I am quite new to HA and need some help.
I want to create some kind of sensor from an external IP (IPv4) address.
To get the IP, I have a simple shell script, which I can execute in HA and which returns the desired IP address.
Thanks in advance
Jan
Since it is a shell script you can use the command_line integration.
  - platform: command_line
    name: External IP Address
    command: "curl -s https://api.ipify.org"
    scan_interval: 300
    unique_id: external_ip_address
If you just want to get your public IP address use this with the default configuration values:
Can also pull it via SNMP from your router, if your router supports that.
I tried this, but what the docs say is the SNMP OID for the public/wan ip actually turns out to be the ISP’s gateway ip. I’ve gone over it repeatedly, checking several whats-mp-ip sites.
Of note, I have a dynamic external ip.
This works for me:
- platform: rest
  resource: "https://api.ipify.org/?format=json"
  value_template: "{{ value_json.ip }}"
Unknown error occurred
Seems this has a long term issue, and not been fixed ??
