Create Sensor from MQTT JSON from power meter ADW300
I’m not familar to deal withe JSON beacuse I’m new in Home Assitant.
I want to create seperate sensors in Home Assistant for my power meter witch communicate by MQTT.
By the MQTT Explorer I get the follwing Data from the power meter:
{“data”:[{“tp”:1748120962627,“point”:[{“id”:0,“val”:“24032006080001”},{“id”:1,“val”:234.8},{“id”:2,“val”:234},{“id”:3,“val”:235.5},{“id”:4,“val”:405.9},{“id”:5,“val”:406.5},{“id”:6,“val”:407.2},{“id”:7,“val”:1.08},{“id”:8,“val”:1.39},{“id”:9,“val”:1.91},{“id”:10,“val”:-0.108},{“id”:11,“val”:-0.041},{“id”:12,“val”:-0.09},{“id”:13,“val”:-0.24},{“id”:14,“val”:-0.203},{“id”:15,“val”:-0.305},{“id”:16,“val”:-0.426},{“id”:17,“val”:-0.934},{“id”:18,“val”:0.23},{“id”:19,“val”:0.307},{“id”:20,“val”:0.435},{“id”:21,“val”:0.964},{“id”:22,“val”:0.471},{“id”:23,“val”:0.135},{“id”:24,“val”:0.206},{“id”:25,“val”:0.248},{“id”:26,“val”:50},{“id”:27,“val”:38},{“id”:28,“val”:168.55},{“id”:29,“val”:416.29},{“id”:30,“val”:0.73},{“id”:31,“val”:189.01},{“id”:32,“val”:0},{“id”:33,“val”:“d8:bc:38:7f:d1:2c”},{“id”:34,“val”:1},{“id”:35,“val”:1}]}]}
For example:
{“id”:13,“val”:-0.24} is the total active power in kW
{“id”:28,“val”:168.55} is the forward active enrgy consumption in kWh
{“id”:29,“val”:416.29} is the reversing active enrgy consumption in kWh
Inspired by the forum I tried sevral mqtt sensor configurations in the /homeassistant/configuration.yaml but get no values.
I would be great if somone could give me one example for the sensor configuration.
Start by adding what you tried and show the path in MQTT Explorer, e.g. screenshot.
Example configuration.yaml entry
mqtt:
  • name: “Gesamtleistung”
    state_topic: “Sensor/ADW300/Gesamtleistung1”
    unit_of_measurement: ‘kW’
    value_template: “{{ value_json[‘data’].[‘point’].[‘id’].[‘13’].[‘val’] }}”
My Problem is the value Template, i do not now the right syntax.
When you paste json etc. please format it correctly as this is unusable due to incorrect hyphenation.
there are lists in the json so you have to direct it to the correct element in the list. If your target-data is stable in the same element then you can use this, else it wil lbe more complex and you would need to load on a higher level and add a separate template sensor with more logic
try this in devtools > template
{% set vj = {
  "data": [
      "tp": 1748120962627,
      "point": [
          "id": 0,
          "val": "24032006080001"
          "id": 1,
          "val": 234.8
          "id": 2,
          "val": 234
{{ vj.data.0.point.0.val }}
