Create sensor kw from acumulative data in kwh
I’m using an integration to get all data from AC, but it only gets kwh data, I’m interested to analize realtime data ( at least as soon as I can ), I’ve created this script but it doesn’t work, could you help me with that?
      consumo_acumulado:
        value_template: "{{ states('sensor.consum_giatsu') | float }}"
        unit_of_measurement: "kWh"
      instant_power:
        friendly_name: "Potencia Instantánea"
        unit_of_measurement: "kW"
        value_template: >-
          {% set current_consumption = states('sensor.consumo_acumulado') | float %}
          {% set last_consumption = state_attr('sensor.consumo_acumulado', 'last_consumption') | float(default=0) %}
          {% set last_time = state_attr('sensor.consumo_acumulado', 'last_time') | float(default=0) %}
          {% set current_time = now().timestamp() %}
          {% set elapsed_time = current_time - last_time %}
          {% if elapsed_time > 0 %}
            {{ ((current_consumption - last_consumption) / elapsed_time) | round(2) }}
          {% else %}
            0
          {% endif %}
Take the derivative of energy to get power using this integration:
