Create separate integration for alarmdecoder webapp
I’m not sure what the best way to do this would be to update the alarmdecoder integration.
The Alarmdecoder device has a webapp which has a REST API. It would be much easier to setup this integration using config flow if you use an API key from the webapp, that way you can grab and enter all the zones. You can find documentation for the API here
It also appears there is a python module here
I’m not much of a coder so can’t tell if it will let you grab the rfid’s as well.
I understand that not everyone has the webapp running so it may be a better idea to create a separate integration just for the webapp. Not much of a coder but would be glad to help test this out!
