EvertJob
(Toppe)
August 17, 2022, 11:53am
1
Currently I’m using this config and this is working very well.
trigger_pin: GPIO14
echo_pin: GPIO12
name: "Zoutniveau waterontharder"
update_interval: 2s
timeout: 2.0m
filters:
- median:
window_size: 15
- lambda: return (0.51-x)*100;
unit_of_measurement: "cm"
But I would like to create a new virtual sensor and make a math calculation on it. This is the exact math:
0 + ((35-0) / (51 - 5)) * (id(ontharder).state - 5)
But what ever I’m trying I cannot make it work. Everything results in “OFF” or “NaN M”
name: "Waterontharder in KG"
lambda: |-
return(0 + ((35-0) / (51 - 5)) * (id(ontharder).state - 5));
Some one who can give me a push to the right direction?
Hellis81
(Hellis81)
August 17, 2022, 12:03pm
2
I think either:
lambda: |-
return((35 / 46) * (id(ontharder)- 5));
or:
lambda: |-
return((35 / 46) * (int(id(ontharder)) - 5));
If you want to simplify the math also.
EvertJob
(Toppe)
August 17, 2022, 12:14pm
3
The result is 0.0, whatever I’m trying. Even after replacing id(ontharder)
with a fixed number.
I’f im trying to do this: return 2*2;
the output is. 4.0 so it’s in the good direction
I tried this and it seems to work:
lambda: |-
return ((35 / 46) * (id(ontharder).state - 5));
You might need to add update_interval
as without it it will only update every minute
EvertJob
(Toppe)
August 17, 2022, 12:44pm
5
Don’t know why, but my result is still 0.0:
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-0C14F8"
password: "f0SZDyGJNFc3"
captive_portal:
text_sensor:
- platform: wifi_info
ip_address:
name: ESP IP Address
ssid:
name: ESP Connected SSID
name: Uptime Human Readable
icon: mdi:clock-start
- platform: uptime
update_interval: 60s
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
- platform: ultrasonic
trigger_pin: GPIO14
echo_pin: GPIO12
update_interval: 2s
timeout: 2.0m
filters:
- median:
window_size: 15
- platform: wifi_signal
name: "WiFi Signal Sensor"
lambda: |-
update_interval: 1s
What’s the value (state) of “Zoutniveau waterontharder”
EvertJob
(Toppe)
August 17, 2022, 12:51pm
7
Zoutniveau waterontharder 20.66 cm
Even this results into 0.0:
lambda: |-
return ((35/46)*(20-5));
update_interval: 1s
Tried some more stuff and. this don’t work:
lambda: |-
return (35/46)*20;
update_interval: 1s
But this results is 350:
lambda: |-
return (35/2)*20;
update_interval: 1s
Looks like ESPHome don’t like it the first math part is below zero?
EvertJob:
maybe so, this works for me:
return 0.76086956521739130434782608695652*(20-5);
tom_l
August 17, 2022, 1:23pm
9
If you just want to enter the two points of your linear equation so that you can adjust them, use the calibrate linear filter.
https://esphome.io/components/sensor/index.html#calibrate-linear
EvertJob
(Toppe)
10
Yep,
Just. tried this:
lambda: |-
return 0.74468085106 * (id(ontharder).state - 5);
update_interval: 1s
And that reports “11.7”
When I change 0.74468085106
into (35/46)
it don’t work.
I will make a bug report at GitHub!
EvertJob
(Toppe)
August 17, 2022, 1:24pm
11
I want to have both values.
tom_l
August 17, 2022, 1:26pm
12
So use a template sensor that grabs your ultrasonic sensor state and applies the calibrate linear filter.
EvertJob
(Toppe)
August 17, 2022, 1:27pm
13
If that’s possible I will have a look into it. ESPHome is very new for me so I don’t have much experience with it.
EvertJob
(Toppe)
August 17, 2022, 1:29pm
15
Thanks, will get this working before starting with the filter option
EvertJob
(Toppe)
August 17, 2022, 9:21pm
17
Because I’m already happy I’ve got this working
