Hi all
I’m trying to create my first addon, i’m going with the local addon route for now. I’ve looked at the documentation and done the basic hello world tutorial which works. I want to now try and use a specific component someone wrote as a docker container and wrap it in my custom addon. I cant install it as a stand alone docker container because from what i understand, this is not possible in home assistant OS and all docker containers / images need to be installed through an addon.
I dont get very far once i start trying to include the docker image, hoping someone could pleae help steer me.
this is the docker hub image i want to use : Docker Hub
this is my /addon/voltronic/config.yaml file
description: "My first real add-on!"
version: "1.0.0"
slug: "hello_world"
init: false
arch:
- aarch64
- amd64
- armhf
- armv7
- i386
image: "bushrangers/ha-voltronic-mqtt"
this is the error i get when i try and install the addon:
Can't install bushrangers/ha-voltronic-mqtt:1.0.0: 404 Client Error for http+docker://localhost/v1.41/images/create?tag=1.0.0&fromImage=bushrangers%2Fha-voltronic-mqtt&platform=linux%2Farm64: Not Found ("manifest for bushrangers/ha-voltronic-mqtt:1.0.0 not found: manifest unknown: manifest unknown")
