Creating a RAID array in Home Assistant 9.3
I’d like to install Frigate for NVR purposes. I have 4 hard drives available for the /media folder. Cannot, for the life of me, figure out how to make the array. I’ve made the partitions (/dev/sda1, /dev/sdb1,etc), when using mdadm I get a permission denied error. Any clues?
Figured out the only way to do it is by installing Supervised. Then you can still access the base OS, create the array, etc. Frigate is recording right now onto the array.
So, you installed Debian OS first and then installed HA Supervised right?
Correct. Install Debian, make and mount the array to your desired location, then install supervised, then config Frigate to store to that location.
