Creating a switch for an existing heater entity
Hi, I have in my living-room two adax heaters, integrated with the Adax integration.
The problem I am trying to solve is to have HA control the heater through an external temperature sensor (The internal ones are not working properly in the heaters).
I have looked up various smart thermometers, but they rely on a switch it seems.
So,
  1. How can I create a switch which sets the temperature to the desired temperature when on, and a low temperature when off
  2. A thermostat which can handle the above description.
Thank you for you attention :slight_smile:
I was dealing with a similar problem (not ADAX heater though).
My approach was to set Generic Thermostat with external thermometer and an automation to set the temperature on the actual device to 35 °C when generic thermostat demanded heat and to 5 °C once generic thermostat stopped heating.
I hope this helps.
