I have 13 STZW402+ thermostats in my house, and they are all working great, however, the only way I have found to automate them is to create scenes. Each device has 3 entities: climate, zwave, sensor. Climate is the one I used in my dashboards, and to create scenes, but it’s not a “device” so I can’t use it in an automation.
Is there something obvious that I am missing?
But you should have multiple service options for climate which can be used in automations.
CLIMATE CONTROL SERVICES
Available services: climate.set_aux_heat
, climate.set_preset_mode
, climate.set_temperature
, climate.set_humidity
, climate.set_fan_mode
, climate.set_hvac_mode
, climate.set_swing_mode
, climate.turn_on
, climate.turn_off
How did I miss that?? Thank you so much!
