The number selector (level) is text , if i remove the quotes ’ the blueprint works. If this correct ? should a number selector be saved as text ? If so how can I convert the text to a number so my condition works
You could create a variable to represent the input selector’s value. Afterwards, you can convert the variable’s value to an int. However, I don’t believe you can use templates in a State Condition, so you’ll have to use a Template Condition.
Here’s an example of what I mean using the shorthand notation for a Template Condition:
Thanks @123. I had come to the same conclusion. Just wanted to make sure I wasn’t missing anything
Your solution is simple and concise. edit i cannot add your comment as a solution tick box is missing ?
It just seems very odd and inelegant to setup one set of variables in the blueprint , just to replace them with another set in the automation.
Unfortunately I have discovered there is no actual text selector in the blueprint schema ?
The number selector is a text selector which you cannot use with text !!
So I cannot use the blueprint to quickly create multiple notifications . I could use input_text helpers, but again , the whole point of the blueprint is to create multiple automatons quickly without any programming skills.
I think blueprints will evolve quickly to add these features and become a very powerful script generator.
