Creating Entity with attributes
if the entity is created with mqtt auto discovery i get it with attributes
If i create entity manual i get only state
So is there a way to make them also with attributes?
Thanks a lot!
Which integration are you using to create the entity?
Sorry, under manual i mean configuration.yaml
In right this case it is mqtt sensor of zigbee2mqtt.
Mqtt is the integration. Sorry I should have known that from “mqtt discovery”
You have to add the attributes topic and value template: https://www.home-assistant.io/integrations/sensor.mqtt/#json_attributes_template
Oh, looks like exact what i need! Thanks a lot!
So it depends on integration as i understood, and for example with input_boolean or switch it is not to realize?
Correct. e.g. An mqtt switch does support attributes a command line switch does not.
