TLDR you can mount the system partition on a linux machine and edit how they handle the ssh session to get a normal shell instead of the locked down crestron command line thing and start adbd.
For the following, the SD card in my machine is /dev/sda and the IP on my network is 10.1.66.5
Steps:
- Create a backup just in case
sudo dd if=/dev/sda of=backup.img bs=4M status=progress
- Mount partition 2
sudo mkdir /mnt/tmp
sudo mount /dev/sda2 /mnt/tmp
- Edit the file
Using the editor of your choice, open the file /mnt/tmp/bin/sshShell.sh
Find the line /system/bin/telnetSSHProxy SSH $1 and replace it with /system/bin/sh
save the file
- Cleanup etc
sudo umount /mnt/tmp
Reassemble the device, now once it starts up if you connect via ssh:
ssh [email protected]
you should get a normal shell
crestron@android:/ #
run start adbd
Now you can connect with adb
adb connect 10.1.66.5
adb shell
Should yield
root@android:/ #
Ideally we would be able to just enable adbd autostart but from my limited knowledge of how android works this is handled by files in the boot partition which is in a weird format on this device and I haven’t looked into it much.
