Critical Hourly CPU Spikes (90°C) and System Freeze on Intel NUC (32GB RAM)
Hi everyone,
I’m facing a frustrating issue with my Home Assistant setup that I haven’t been able to solve. Every hour, like clockwork, my system experiences a massive resource spike that practically renders it useless for a few minutes.
The Symptoms:
Cyclical Spikes: Happens exactly every hour.
Temperature: CPU temp jumps rapidly to around 90°C.
Resource Usage: Huge spikes in CPU and Memory usage.
System Instability: During the spike, I experience complete disconnections from the server. The UI becomes unresponsive, and I lose access for several seconds to a few minutes.
My Hardware/Setup:
Machine: Intel NUC
Memory: 32GB RAM (So hardware overhead shouldn’t be the issue).
Storage: SSD
Installation: [תשלים כאן: HAOS / Proxmox VM / Docker]
What I’ve Checked:
I’ve looked at my automations, and nothing is explicitly scheduled to run at the top of every hour.
Given the 32GB of RAM, I suspect a specific integration or a “zombie process” rather than a simple lack of resources.
The fact that it’s so precisely hourly points toward a scheduled task (like a database purge, backup, or a cloud sync).
My Questions:
Has anyone experienced similar hourly “lock-ups” on high-end hardware like a NUC?
What is the best way to “live monitor” which specific process or Add-on is causing the spike when the UI is frozen? (Should I use SSH/top, or a specific Add-on like Glances?)
Are there any known integrations or Recorder settings that are notorious for hourly CPU-intensive tasks?
I would appreciate any guidance on how to debug this further before the heat causes any long-term damage to my NUC.
Thanks in advance for the help!
Disable your add-ons one at a time and see. If you have a bunch, you can do a couple or several at a time to narrow it down faster.
I wonder would it be faster initially to disable 1/2 the addons and if still getting the spikes 1/2 again. Each time dont get the spikes move to other section until you have narrowed it down to one. If that doesn’t work then try something else
Custom Integrations are just as likely to cause this, so do the same with them.
Booting is safe mode turns all this off.
Besides software, did you check the hardware? Is the fan working? Is the CPU correctly mounted, no dried out heat paste?
this is the output of the profiler
