Current State node... what am I doing wrong?
When I set up the Current State node as in this screenshot it does nothing when the entity switches to on. I must be overlooking something in the node’s configuration because when I use the Trigger: State node it fires. Any help will be greatly appreciated.
It is not a trigger, it is a conditional. Your asking what is the current state of an entity. Like sundown set off a trigger then a current state would check is the light on, if not turn it on, otherwise do nothing.
If you want a trigger with the time component use the event state node.
