I have a grid of custom:button-card buttons whose icon is dynamic and that are made visible based on some sensor state (a sensor for radio presets). That part works fine for me and my setup.
I tried to do the same for a friend. The sensors, … are the same, but the tap action is slightly different.
For me (working), I have this:
tap_action:
action: call-service
service: rest_command.bluos_play
service_data:
url: |
return states['sensor.bluos_preset_1'].attributes['@url']
That’s rest_command with a url parameter that is configured in Configuration.yaml. So far so good.
Now, for my friend, I don’t have a rest_command but the equivalent is sequence of actions I configured in the UI under Parameters > Automations and Scenes > Scripts.
The script has id script.lecture_parametree_sur_bluesound_node and is configured like that (just fyi):
sequence:
- action: script.allumer_onkyo_sur_bluesound
metadata: {}
data: {}
enabled: true
- action: rest_command.bluos_play
url: "{{ url }}"
enabled: true
alias: Lecture paramétrée sur Bluesound NODE
description: ""
icon: mdi:folder-play
fields:
url:
description: URL du flux BluOS
example: ""
So I want to adapt my tap_action in that context to basically run that “script” and pass the same sensor attribute @url to the url parameter.
I tried this:
tap_action:
service: script.lecture_parametree_sur_bluesound_node
service_data:
url: |
but this fails with “action script.lecture_parametree_sur_bluesound_node not found”.
So, based on the YAML configuration of the corresponding script and seeing how another script is actually called right as an action, I tried to change to:
tap_action:
action: script.lecture_parametree_sur_bluesound_node
url: |
There is no errors, but nothing happens and when I go to Settings… Scripts, the last trigger always shows “never”.
So obviously I don’t get what “action” to be invoked or do I just “execute” a script… and I’m just unable to find the answer by looking around. Somehow custom:button-card seems to be slightly different in how it works and it’s hard for me at this stage to figure out how to adapt.
