Custom Button Card - Using state value of a numeric value
I’m trying to take the value of a power monitoring plug and if its above 2 watts, change the colour of an icon. This is what I have so far:-
type: custom:button-card
entity: sensor.tz3000_okaz9tjs_ts011f_active_power_2
tap_action:
  action: navigate
  navigation_path: /dashboard-rooms/office
icon: mdi:desktop-classic
styles:
  card:
    - height: 100px
    - font-size: 18px
    - font-weight: normal
    - icon:
        - color: |
              var is_on = parseFloat(entity.state)>2? 'on' : 'off';
              if (is_on == "on") return "#4D4D4D";
              if (is_on == "off") return "#FFFFFF";
I added parseFloat incase the value of entity.state was not a numeric, but I can’t seem to get the colour to change from anything other than white.
I can see the value I need via the dev tools templates menu:-
What am I doing wrong ?
P.S. I do have working examples, but they require the state of the entity to be a specific value, rather than greater than.
entity: light.moes_rgb_bulb_first_floor_hall_light
tap_action:
  action: navigate
  navigation_path: /dashboard-rooms/hallways
styles:
  card:
    - height: 100px
    - font-size: 18px
state:
  - value: 'on'
    icon: mdi:faucet
    color: yellow
  - value: 'off'
    icon: mdi:lightbulb
    color: rgb(68,115,158)
Try this:
- color: |
              if (states['sensor.tz3000_okaz9tjs_ts011f_active_power_2'].satte > 2) return "#4D4D4D";
              if (states['sensor.tz3000_okaz9tjs_ts011f_active_power_2'].satte <= 2) return "#FFFFFF";
…might need quotes around the 2 ➜ '2'
Unfortunately still doesn’t work… Icon stays white with this code:-
    - icon:
        - color: |
              if (states['sensor.tz3000_okaz9tjs_ts011f_active_power_2'].state > 2) return "#4D4D4D";
              if (states['sensor.tz3000_okaz9tjs_ts011f_active_power_2'].state <= 2) return "#FFFFFF";
I suspect its because the entity is defined earlier in the button card config, and you usually then access its state by using ‘entity.state’
I can get around it by creating a template sensor but wondered if there was a way of doing it directly in the card.
Turns out the answer was in the docs all along:
state:
  - value: 2
    operator: '>='
    color: yellow
  - value: 2
    operator: '<'
No, you can still reference the entity as I showed. I didn’t think entity.state worked for custom:button-card though - good to know!
Glad you solved it.
This isn’t work for me. Any clue? Here is my template:
energy:
  styles:
    state:
      - box-sizing: border-box
      - display: flex
      - align-items: end;
      - font-family: ui-rounded, system-ui, "SF Pro Text", Roboto, sans-serif
#      - color: "var(--primary-text-color)"
      - grid-area: value
      - font-size: 12px
      - line-height: 15px
      - font-weight: 600
      - text-align: left
      - width: 100%
      - align-self: end
      - value: 0.3
        operator: '>='
        color: rgb(252,127,3)
      - value: 0.3
        operator: '<'
        color: rgb(111,176,0)
Shouldn’t it be:
styles:
  energy:
    - display: flex
    - align-items: end;
    - grid-area: value
    - font-size: 12px
    - line-height: 15px
    - font-weight: 600
    - text-align: left
    - width: 100%
    - align-self: end
states:
    - value: 0.3
      operator: '>='
    - value: 0.3
      operator: '<'
I am not sure. The first line is the name of the template so it can’t be styles. But following your code I could separate styles and states and see what happens.
energy:
  styles:
    - display: flex
    - align-items: end;
    - grid-area: value
    - font-size: 12px
    - line-height: 15px
    - font-weight: 600
    - text-align: left
    - width: 100%
    - align-self: end
  states:
      - value: 0.3
        operator: '>='
      - value: 0.3
        operator: '<'
No, it didn’t apply any of the styles. I guess it’s something else. Basically, the state color works, but only the last one on the bottom.
Sorry, didn’t realise that was a template.
No problem. I hope someone can help.
Have you tried to move the “states: - values section” in line with above - ( the indentation doesn’t seems right the - should start under the “a” in states:
Oh yes, I tried that as well. The template is this and when applied to the cards (the right one needs to have its own template) it does give this result:
utility:
  show_state: true
  state_display: |
      if (entity) {
        var value = states[entity.entity_id];
        if (
          value
          && value.attributes
          && value.attributes.unit_of_measurement
          && value.attributes.unit_of_measurement === "$/kWh")
          var formattedState = Number(value.state);
          return `${formattedState.toFixed(2)} $/kWh`;
        return `${value.state}`;
      return null;
  styles:
    grid:
      - grid-template-columns: 32px auto
      - grid-template-areas: |
          "icon value"
          "icon name"
      - grid-template-rows: 19px 13px
      - column-gap: 4px
      - row-gap: 0px
      - padding-right: 8px
      - padding-left: 8px
      - padding-top: 8px
      - padding-bottom: 8px
    img_cell:
      - display: none
    custom_fields:
      icon:
        - color: "var(--secondary-text-color)"
        - height: 32px
    state:
      - display: flex
      - align-items: end;
      - grid-area: value
      - font-size: 12px
      - line-height: 15px
      - font-weight: 600
      - text-align: left
      - width: 100%
      - align-self: end
      - value: 0.3
        operator: '>='
      - value: 0.3
        operator: '<'
        color: rgb(0, 190, 29)
Well, you keep posting a fraction of what you are doing. and maybe you are mixing up, yaml-Template-Sensors, and template/style in Custom:button Card, i really don’t know, and cant tell from you “fraction done somewhere”
No worries. There is a lot to learn, try and retry. I don’t know either. I have a couple of ideas tho.
Can anyone point me in the right direction, I thought I can figured this out, but it only seems to work with two states not three?? See code below
entity: sensor.living_room_sensor_temperature
show_state: true
icon: mdi:thermometer
state:
  - value: 4
    operator: '<'
    color: blue
  - value: 4
    operator: '>='
    color: green
  - value: 10
    operator: '>='
    color: orange
I’m trying to get the icon to change color based on three different temperatures. My sensor temp is currently higher than 10, so I thought it would be orange, but its still green. Maybe I’m doing something wrong??
I know this is old thread. If you are still looking for answer then try the values in higher to lower.
show_state: true
state:
  - value: 10
    operator: '>='
    color: orange
  - value: 4
    operator: '>='
    color: green
  - value: 4
    operator: '<'
    color: blue
