Hi all,
I’d like to share EnerLens Card, an energy flow card I’ve been building for my own PV setup and have now polished enough to publish.
It draws the familiar cross of solar, grid, house and battery with moving dots — and then answers the question the usual cross leaves open: what is the house figure actually made of?
What it does differently
- Consumer breakdown instead of extra nodes. If you measure individual devices (a heat pump, a Shelly plug, …), add their entities. A list beside the house node and a ring around it show how the house consumption splits up; a remainder row holds everything not measured individually.
- The list sorts itself and glides. Rows reorder by power on a fixed beat and slide into place, and the ring segments travel with them. A filter button shows every consumer on demand — handy for tapping the history of a device that just went quiet.
- Moving averages. Live values jump by kilowatts within seconds. One tap switches to a 2 or 15 minute moving average (both configurable) to calm the picture down — clicking any node still opens the normal history dialog.
- Grid outage display. If your inverter reports grid status, the card shows a red banner and a crossed-out grid node instead of a misleading “0 W”.
- Narrow columns. On a phone or in a narrow column the list moves below the cross.
Practical bits
- Full GUI editor — no YAML needed. Signed sensors, inverted sensors, separate import/export entities, or one quantity derived from the others are all choices in the form.
- Same sign convention as Home Assistant and power-flow-card-plus, so existing sensors usually work as they are. There’s a short migration section in the README.
- Defaults to the energy dashboard colours; every colour can be changed with a built-in colour picker, including
var(--…)theme values. - English and German, following your HA profile language. Adding a language is just a JSON file.
- Light and dark, follows the theme or can be forced per card.
Install
Via HACS → ⋮ → Custom repositories, add https://github.com/wawersich/enerlens-card as type Dashboard, then search for EnerLens.
(Inclusion in the default HACS list is pending.)
Minimal config:
type: custom:enerlens-card
entities:
solar: sensor.pv_power
grid: sensor.grid_power
house: sensor.house_power
Feedback, ideas and bug reports are very welcome — here or as a GitHub issue. I’m especially curious how it copes with inverter setups I don’t have myself.
