[Custom Card] Moglie HA - A Reactive, Multi-Entity Status Card
Looking for a fun way to monitor your WAN, Alarm, and Weather all in one spot?
Moglie HA is a standalone custom card that uses a reactive "Outfit Engine" to display home status:
  • WAN Watchdog: Moglie goes grayscale and "stranded" if your internet drops.
  • Weather Intelligence: Rain, Snow, Heat, and Humidity (new!) triggers.
  • Full UI Editor: No YAML required. Includes a dynamic dropdown to enable/disable specific monitoring features to keep your config clean.
  • Custom Quotes: Every state has a default "Monkey Quote," but you can override them all with your own custom personality.
    Get Moglie on GitHub!
What does that mean?
:joy: The monkey will probably start dressing according to the weather.
Correct! Moglie is aware of the weather, if you give him the entity. He gears up when the weather gets severe (hot, cold, humid, raining), no matter the current weather, Moglie will be ready for it! Also Moglie has other outfits too! Check when times get 'Jolly' :wink:
