**Describe the bug**
Every Dreame integration (v2.0.0b16) entity becomes unavai…lable after approximately 1 hour.
**To Reproduce**
I wait for approximately 1 hour. The integration must be reloaded in order for the entities to be refreshed or made available.
I have deleted the integration and re-installed it and I have the same issue.
**Expected behavior**
Entities to be available.
**Screenshots**
If applicable, add screenshots to help explain your problem.
![image](https://github.com/user-attachments/assets/f5ac2225-a221-4410-9b21-4b057190d623)
**Additional Information (please complete the following information)**
- Model Name: Dreame XL30 Ultra r9316k
- Firmware Version [e.g. 1156]: 4.3.9_1726
- Home Assistant Version: Core 2014.9.1 O/S 13.1
- Configuration Type [With or without map support]: Dreame Account
- Errors or warnings shown in the HA logs (if applicable):
Edit:
Strange... the following error has shown up in the Core log. It has only shown up once. Below this error are the DNS errors.
This error originated from a custom integration.
Logger: custom_components.dreame_vacuum.dreame.protocol
Source: custom_components/dreame_vacuum/dreame/protocol.py:567
integration: Dreame Vacuum (documentation, issues)
First occurred: 5:29:10 PM (1 occurrences)
Last logged: 5:29:10 PM
Error while executing request: Read timed out. (read timeout=3): {"did":"521426587","id":82,"data":{"did":"521426587","id":82,"method":"get_properties","params":[{"did":"0","siid":2,"piid":1},{"did":"1","siid":2,"piid":2},{"did":"2","siid":3,"piid":1},{"did":"3","siid":3,"piid":2},{"did":"5","siid":4,"piid":1},{"did":"10","siid":4,"piid":6},{"did":"11","siid":4,"piid":7},{"did":"39","siid":4,"piid":35},{"did":"24","siid":4,"piid":20},{"did":"29","siid":4,"piid":25},{"did":"121","siid":15,"piid":3},{"did":"122","siid":15,"piid":5},{"did":"21","siid":4,"piid":17},{"did":"34","siid":4,"piid":30},{"did":"51","siid":4,"piid":47}]}}
The only errors I see by default are the following DNS errors.
[INFO] 127.0.0.1:55527 - 27810 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000061683s
[INFO] 127.0.0.1:36837 - 18322 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.001261635s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. AAAA: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:40178 - 5771 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.001261698s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. A: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 172.30.32.1:40755 - 33633 "A IN us.iot.dreame.tech. udp 36 false 512" - - 0 8.002630949s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. A: read udp 127.0.0.1:60776->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.1:40755 - 33810 "AAAA IN us.iot.dreame.tech. udp 36 false 512" - - 0 8.002917648s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. AAAA: read udp 127.0.0.1:45978->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:51032 - 31159 "NS IN . udp 17 false 512" REFUSED qr,aa,rd 17 0.000081415s
[INFO] 127.0.0.1:54682 - 45305 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000378569s
[INFO] 127.0.0.1:37568 - 45407 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000378553s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. AAAA: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:32845 - 29181 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000201887s
[INFO] 127.0.0.1:60006 - 16969 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000152291s
[INFO] 127.0.0.1:57831 - 33500 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000334348s
[INFO] 127.0.0.1:41216 - 8150 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000385717s
[INFO] 127.0.0.1:53766 - 16539 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 19.431556798s
[INFO] 127.0.0.1:44538 - 4678 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 19.431571704s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. AAAA: dial tcp 1.0.0.1:853: connect: network is unreachable
[ERROR] plugin/errors: 2 us.iot.dreame.tech. A: dial tcp 1.0.0.1:853: connect: network is unreachable
[INFO] 127.0.0.1:50688 - 36599 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000244126s
[INFO] 127.0.0.1:37031 - 17691 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000150386s
[INFO] 127.0.0.1:51653 - 48859 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.00098477s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. A: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:45282 - 9292 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.001699655s
[INFO] 127.0.0.1:37340 - 7260 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000363634s
[INFO] 127.0.0.1:50953 - 60302 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000362694s
[INFO] 127.0.0.1:38433 - 46687 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 21.66733183s
[ERROR] plugin/errors: 2 us.iot.dreame.tech. A: read tcp 172.30.32.3:53422->1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:49765 - 29561 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000985441s
[INFO] 127.0.0.1:51819 - 53524 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000906347s
[INFO] 127.0.0.1:60278 - 43903 "AAAA IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000856317s
[ERROR] plugin/errors: 2 10000.mt.us.iot.dreame.tech. AAAA: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:60835 - 62115 "A IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000856304s
[ERROR] plugin/errors: 2 10000.mt.us.iot.dreame.tech. A: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:41375 - 28445 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000899684s
[INFO] 127.0.0.1:37798 - 15745 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000984844s
[INFO] 127.0.0.1:48107 - 2520 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000370637s
[INFO] 127.0.0.1:38474 - 6718 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000370647s
[INFO] 127.0.0.1:57905 - 1993 "A IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000942313s
[ERROR] plugin/errors: 2 10000.mt.us.iot.dreame.tech. A: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:60115 - 55861 "AAAA IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000883206s
[ERROR] plugin/errors: 2 10000.mt.us.iot.dreame.tech. AAAA: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:32920 - 39228 "AAAA IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000412402s
[INFO] 127.0.0.1:50505 - 37890 "A IN us.iot.dreame.tech. udp 47 true 2048" - - 0 30.000343704s
[INFO] 127.0.0.1:41550 - 52477 "AAAA IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000415663s
[INFO] 127.0.0.1:37411 - 58318 "A IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000329174s
[INFO] 127.0.0.1:49673 - 15388 "AAAA IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.00077641s
[INFO] 127.0.0.1:36497 - 32539 "A IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000812839s
[INFO] 127.0.0.1:37815 - 14543 "AAAA IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000470814s
[INFO] 127.0.0.1:37474 - 36886 "A IN 10000.mt.us.iot.dreame.tech. udp 56 true 2048" - - 0 30.000611751s
